vb.net arcobjects strange when using feature store
2887
6
10-19-2014 09:35 PM
LiYao
Dear all,
I met a strange thing when I am trying to update value in attribute table. I am in editing session and after I perform feature.store and open the attribute table, there is no record in the attribute table. When I exit editing session, the records return, but the value not updated.
My code is as follows:
        pActiveView = pMxDoc.FocusMap
        pMxDoc = My.ArcMap.Application.Document
        pMap = pMxDoc.FocusMap
        Dim layerNum = GetIndexNumberFromLayerName(pActiveView, "proj_db.DBO.Line")
        Dim pFLayer As IFeatureLayer
        pFLayer = pMap.Layer(layerNum)
        Dim featureClass As ESRI.ArcGIS.Geodatabase.IFeatureClass = pFLayer.FeatureClass
        If featureClass is DbNull.value then
              Return
        End If
        Dim feature as IFeature = pFLayer.FeatureClass.GetFeature(maxOBJECID)
        If feature is DbNull.value then
          Return
        End If
        Dim nameFieldIndex As Integer = pFLayer.FindField("Seg_ID")
        feature.Value(nameFieldIndex) = inputSegID
        feature.Store()
There no error also. Don't know what is up in my code, please help me on it, thank you very much!
I am using arcobjects 10.2.2.
DuncanHornby
MVP Notable Contributor
OK the only thing I can think of is export the data to a file geodatabase, adjust the code accordingly and see if it executes with error. If that happens then it would suggest your code is OK and it is some sort of problem with the other database (I guess it is ArcServer)? At that point I'm out of ideas as I don't use enterprise databases.
DuncanHornby
I don't know if this is the problem but I would not have used DbNull.value. I would use Nothing.
So my line would be:
If featureClass is Nothing Then
Same when you test feature.
LiYao
Hi Duncan,
Thank you very much for the reply. But after I modify the code, the result still the same.
The problem is caused by the line feature.store().
Is there errors other than the DBNull? Thanks.
DuncanHornby
Is nameFieldIndex definitely getting set to the correct index position? If you have joins on the table then I believe you will need to prefix it with the table name.
LiYao
Hi Duncan,
Thanks a lot for the answer. After I add the table name before the field name, it still not work.
If I use:
Dim nameFieldIndex As Integer = pFLayer.FindField("proj_db.DBO.Line.Seg_ID")
Then the application will exit.
If I use:
Dim nameFieldIndex As Integer = pFLayer.FeatureClass.FindField("proj_db.DBO.Line.Seg_ID")
It will still the strange result as described in the question.
Totally no idea on it.....
DuncanHornby
LiYao
Hi Duncan,
Thank you so much for the kind help. I will look further according to your suggestion.
