Error when adding a feature layer
4685
10-13-2014 12:53 PM
joepublic
I have a very basic script show below and get the error:
Any ideas as to what I'm doing wrong??
Error {code: 500, message: "Error performing query operation", details: Array[0], log: undefined, httpCode: 500}
  1. _ssl: undefined
  2. code: 500
  3. details: Array[0]
  4. httpCode: 500
  5. log: undefined
  6. message: "Unable to draw graphic (null): Error performing query operation"
  7. stack: "Error↵ at Error (native)↵ at Object.e.load (http://js.arcgis.com/3.10/init.js:619:426)↵ at http://js.arcgis.com/3.10/init.js:187:69↵ at c (http://js.arcgis.com/3.10/init.js:74:221)↵ at d (http://js.arcgis.com/3.10/init.js:74:10)↵ at resolve.callback (http://js.arcgis.com/3.10/init.js:75:350)↵ at c (http://js.arcgis.com/3.10/init.js:74:436)↵ at d (http://js.arcgis.com/3.10/init.js:74:10)↵ at resolve.callback (http://js.arcgis.com/3.10/init.js:75:350)↵ at http://js.arcgis.com/3.10/init.js:191:300"
  8. __proto__: d
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<script src="http://js.arcgis.com/3.10/"></script>
<script src="//ajax.googleapis.com/ajax/libs/jquery/1.8.0/jquery.min.js"></script>
</head>
<body>
<div id="mapDiv"></div>
<script type="text/javascript">
var map, featureLayer;
var featureURL = "http://dev.consciousglobalchange.org/arcgis/rest/services/MEP/webmap_catalog/FeatureServer/0";
require(["esri/map", "esri/layers/FeatureLayer", "dojo/domReady!"],function(Map,FeatureLayer) {
map = new Map("mapDiv", {
     center: [-56.049, 38.485],
     zoom: 3,
     basemap: "streets"
var featureLayer = new FeatureLayer(featureURL);
map.addLayer(featureLayer);
</body>
</html>
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Joe,
You will want to keep your script in your <head> tags (see below).  Here is a great tutorial on building your first application.
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
    </style>
      require([
      function(
        Map, FeatureLayer
          zoom: 3,
          basemap: "streets"
        var featureLayer = new FeatureLayer(featureURL,{
          mode: FeatureLayer.MODE_ONDEMAND
    </script>
  </head>
  <body>
  </body>
</html>
JakeSkinner
Hi Joe,
<!DOCTYPE html>
<html>
  <head>
    <style>
        padding:0;
        margin:0;
        height:100%;
    </style>
      require([
      function(
        Map, FeatureLayer
          zoom: 3,
          basemap: "streets"
    </script>
  </head>
  <body>
  </body>
</html>
joepublic
Jake,
I did as you suggested but still the error
Chris
joepublic
Jake,
I think there is problem with the server hosting the esri software
Joe
