"Select by Attributes" query script
4193
5
10-11-2014 08:31 AM
ArielCarballo
I need to write a script that would extract the contents of a text file (see below)
123456
234567
890123
567890
and would write a script that later could be loaded when using "Select by Attributes" tool (see below).
P.S. I have a list of hundreds of numbers that I do not want to enter them one by one.
Your help would be greatly appreciated.
AnthonyGiles
Honored Contributor
Ariel,
if you have your list in a text document you could load it in to excel so each value is in separate rows down one column.
then create a formula to create your expression, e.g:
= "FID = '" & A1 & "'"
where A1 is the first cell that contains a value. Copy the formula down so that each row gets populated. If you the copy the values into notepad then copy and paste them into word ( this stops the column being added as a table in word). You can then do a find and replace to add the 'or' segments into your expression. ^p in word is hard return replace this with space OR space. This should give you your full expression that you can then paste into arcmap.
hope this helps
anthony
DanPatterson_Retired
Rather than select what you do want, it is sometimes quicker to select what you don't want then switch the selection. So to answer this question...if there a range of values that could be used rather than selecting them one at a time.  Would a spatial selection work better than an attribute selection... etc etc etc
ArielCarballo
I have like 85000 items of which I only need to select around 450.
Sent from myMail app for Android
Saturday, 11 October 2014, 02:02PM -0400 from Dan Patterson <[email protected]>:
GeoNet
reply from  Dan Patterson in  Ariel Carballo -  View the full discussion
AnthonyGiles
Honored Contributor
Ariel,
hope this helps
anthony
ArielCarballo
Anthony,
Thanks for your prompt response, I'll try it.
Saturday, 11 October 2014, 02:04PM -0400 from Anthony Giles <[email protected]>:
GeoNet
reply from  Anthony Giles in  Ariel Carballo -  View the full discussion
ArielCarballo
It worked perfectly!! Thanks a lot!!
GeoNet
