python - manage workspace for dynamic layers
4003
10-13-2014 06:36 AM
giancarlorazzino
using python, I would like to manage the publication of a map service with the property of the capabilities Mapping "manage workspace for dynamic layers"
using the following piece of code (highlighted part)
import arcpy
import os.path
import xml.dom.minidom as DOM
arcpy.mapping.CreateMapSDDraft(mapDoc, sddraft, service, 'ARCGIS_SERVER', con, True, "FS", summary, tags)
doc = DOM.parse(sddraft)
keys = doc.getElementsByTagName('Key')
for key in keys:
        if key.firstChild.data == 'enableDynamicLayers': key.nextSibling.firstChild.data = True
        if key.firstChild.data == 'dynamicDataWorkspaces': key.nextSibling.firstChild.data =[{"id":"MyFile_GDBWorkspaceID","workspaceFactory":"FileGDB","workspaceConnection":"database=C:\\PIR\fase230\\PIR_Giugno2014.gdb"}]
        if key.firstChild.data == 'maxRecordCount': key.nextSibling.firstChild.data = 5000
services___ = doc.getElementsByTagName('TypeName')
for service__ in services___:
        if service__.firstChild.data == 'KmlServer':
service__.parentNode.getElementsByTagName('Enabled')[0].firstChild.data = 'false'
        if service__.firstChild.data == 'WMSServer':
service__.parentNode.getElementsByTagName('Enabled')[0].firstChild.data = 'true'
# save changes
if os.path.exists(sddraft): os.remove(sddraft)
f = open(sddraft,"w")
doc.writexml(f)
f.close()
        arcpy.StageService_server(sddraft, sd)
arcpy.UploadServiceDefinition_server(sd, con, service, inCluster)
I have the following error:
exceptions.AttributeError: 'NoneType' object has no attribute 'data'
I think there is an error in the values ​​that pass
Thank you for your help
