Hi to all,
I'm accessing to serviceArea task from javascritp using a proxy file (resource-proxy/Java at master · Esri/resource-proxy · GitHub ) with user e password in config file.
It works for a little after which the token expired (I suppose) and appears the arcgis login form. Bad!
Why the proxy file doesn't request independently a new token? I look into proxy.jsp and it should be done.
I have no more idea, it's two day that I try to change config, try to debug proxy.jsp with no success.
Thank you for any suggest.
Max
