dojox.charting.Chart and dijit.form.Forms both undefined
1011
10-06-2014 08:53 PM
HenryColgate
I am having trouble accessing some of the features of Dojo via the ESRI js.  I have used several links to no avail
http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/
http://js.arcgis.com/3.10/‌
http://js.arcgis.com/3.11/ )
When I try to use dijit.form.Form I hit an undefined error.  I notice that this is not referenced in any of the above links.  I resolved this problem by using dijit.layout.ContentPane.  Notably I could use dijit.form.Button and dijit.form.TextBox so it is not an issue with dijit.form.
Now I am hitting a similar error with dojox.charting however I do not appear to be able to hit dojox.charting at all.  Once again I notice that it is not referenced in the linked Javascript.
I have minimal HTML scripting as I am building nearly everything programatically:
<script src="http://ajax.googleapis.com/ajax/libs/jquery/2.1.1/jquery.min.js"></script>
<script src="http://js.arcgis.com/3.11/"></script>
My Javascript looks like this:
/*global esri*/
/*global dojo*/
/*global dijit*/
/*global dojox*/
function createLineChart(startMeasure, elevations) {
    var lineChart = new dojox.charting.Chart("simplechart");
    lineChart.addPlot("default", {type: "Lines"});
    lineChart.addAxis("x");
    lineChart.addAxis("y", {vertical: "true"});
    lineChart.addSeries("SERIES X", elevations);
    lineChart.render();
The error is on the first line of the function where Chart is undefined, charting is also undefined as is Chart2D.
I am perplexed as to why everything else works but I do not seem to be hit a number of functions from the Dojo toolkit when I can use other functions in the same namespace.
RiyasDeen
Hi Henry,
anything in between /* */ is a comment and is not used during runtime. JavaScript Comments .
The reason you got away with not using requires is because http://js.arcgis.com/3.10/  already requires few modules like button, contentPane etc.
Since you are new to javascript i would recommend you start using AMD straight way instead of legacy dojo.
dojo.require("dojox.charting.Chart"); var chart = new dojox.charting.Chart(); is legacy
require(["dojox/charting/Chart"], function(Chart) { var chart = new Chart(); }); is AMD
Check out these samples at Create a map | ArcGIS API for JavaScript you can get fair bit of understanding on using AMD.
RiyasDeen
Hi Henry,
Chart and Form are included in the Javascript API. http://js.arcgis.com/3.10/js/dojo/dojox/charting/Chart.js , http://js.arcgis.com/3.10/js/dojo/dijit/form/Form.js
Did you require them before using?
dojo.require("dijit.form.Form");
HenryColgate
Hi Riyas,
So far I have managed to get away with not using "dojo.require" at all in my project.  My understanding was that including lines like
/*global dojox*/
should be the same as require. Relatively new to Javscript at the moment so am quite likely making basic errors.
I tried including
in the first line of the createLineChart function with no success but not sure if that is the right place to do it.
RiyasDeen
Hi Henry,
HenryColgate
Awesome Riyas,
Thanks for your help
