Syntax to add one value to numeric field
3350
10-03-2014 02:12 PM
ReneeGerasimtchouk
I have an incremental numeric field that starts with 1 and goes to 400, not unique, meaning there can be numerous 1's and only one 5 and so on. Hence, these were not autonumbers. Is there a syntax (or a way) to add one value to all such as change all 1's to 2's, all 2's to 3's, etc?
DanPatterson_Retired
use the field calculator and add 1 to the values of the field ie in the python parser it would be
!YourFieldNameHere! + 1
ReneeGerasimtchouk
That was super easy, thanks! I just switched to ArcMap from GeoMedia and was unsure of where to start. Thanks again!
