ArcGIS JavaScript API: Legend and checkbox
4469
10-01-2014 03:28 AM
HabG_
Hi All,
I have a web map with three feature layers and one dynamic map layer, and when I use the legend code it is displaying only the three feature layers. What do I need to display all four layers in the legend. Also how do I add a checkbox to display only the checked layers. Here is the code I'm using.
//add the legend
  map.on("layers-add-result", function (evt) {
        var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
          return {layer:layer.layer, title:layer.layer.name};
        if (layerInfo.length > 0) {
          var legendDijit = new Legend({
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
          legendDijit.startup();
JakeSkinner
Esri Esteemed Contributor
Hi Hab,
Here is an example you can refer to that has an ArcGISDynamicServiceLayer in the legend, and a checkbox next to each layer to toggle it on/off.
JakeSkinner
Hi Hab,
HabG_
Thanks Jake.
EzequiasRodrigues_da_Rocha1
I am using this code below in a file mapOverlay.html but it does not work. Could you give me any suggestion? I don't know what template my application was developed.
<!-- SidePanel -->
<div id="sidepanel" style="position:absolute;left:3px;top:3px;z-index:40;">
  <div style="position:absolute;left:3px;top:3px;z-index:40;">
  <div data-dojo-type="dijit/layout/TabContainer" style="width: 320px; height: 100px;" id="TOCdiv" class="dbootstrap">
        <div data-dojo-type="dijit/layout/ContentPane" title="Temas" id="temas"> </div>
        <div data-dojo-type="dijit/layout/ContentPane" title="Legendas" data-dojo-props="title:'Legend'"> </div>
  </div>
  </div>
</div>
JohnRitsko1
Jake, I know this is quite old but figured I would give this a shot in asking a question.  Can you put a legend under each checkbox as they are checked.  I don't want a different tab to show the legend I was users to see the legend for that particular layer as they turn the layer on and off underneath it.  Thanks and hopefully you get this reply.
