ArcGIS JavaScript API: Zoom to point feature using FindTask
3126
6
10-01-2014 03:11 AM
HabG_
Hi All,
I am using the FindTask in my web map (Note: I have point and polygon layers) and it is working fine. When I search using a keyword from the polygon layer it zooms to the polygon and selects the polygon/s using graphics which is what I wanted. However, when I search using a keyword from the point layer, it pans to the center of the selected point/s and doesn't show any graphics. So what I want is, when I search using a point key word, to zoom to the selected point/s and show a circle or square graphics. Below is the code I'm using (Note: I have changed my server name to "myserver:6080").
Thanks.
findTask = new FindTask("http://myserver:6080/arcgis/rest/services/gisdata/webmap/MapServer/");
      map.on("load", function () {
          //Create the find parameters
          findParams = new FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [0, 1, 2];
          findParams.searchFields = ["IDNO", "RESID", "INT", "FTNM"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
        function doFind() {
          //Set the search text to the value in the box
          findParams.searchText = dom.byId("SEARCH").value;
          findTask.execute(findParams, showResults);
        function showResults(results) {
          //This function works with an array of FindResult that the task returns
        var markerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1.5), new Color([255, 0, 0, 0.5]));
        var polygonSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 0, 0, 0.5]));
          //create array of attributes
          var items = arrayUtils.map(results, function (result) {
            var graphic = result.feature;
            graphic.setSymbol(markerSymbol);
            graphic.setSymbol(polygonSymbol);
            map.graphics.add(graphic);
            return result.feature;
          var myFeatureExtent = graphicsUtils.graphicsExtent(items);
          map.setExtent(myFeatureExtent, true);
HabG_
Hi Jake, I changed the second "if" statement to "else" and now I'm able to see the graphics in both point and polygon features. Thanks for your help.
OwenEarley
It seems you are overwriting your point symbol with your polygon symbol:
graphic.setSymbol(polygonSymbol);  // this will replace the previous symbol
You should test the geometry type before setting the appropriate symbol.
HabG_
Thanks for your reply Owen. How do I test the geometry type?
JakeSkinner
Esri Esteemed Contributor
Hi Hab,
You could do something like below:
  if(graphic.geometry.type == 'polygon'){
  if(graphic.geometry.type == 'point'){
HabG_
Hi Jake, the graphics is now showing on the point feature not on the polygon feature.
HabG_
JakeSkinner
Good catch.  That was a type-o on my part.
