Make Query Table
12796
19
09-30-2014 03:26 PM
JeffWard
Honored Contributor
I am having trouble running the Make Table Query tool.  I have run the tool before with success.  I am trying to create a new feature class with one polygon per related record in a table.  The error I get is :
ERROR 999999: Error executing function.
Attribute column not found [42S22:[Microsoft][SQL Server Native Client 10.0][SQL Server]Invalid column name 'V__574.GISID'.] [sde.DBO.QueryTable]
Attribute column not found [42S22:[Microsoft][SQL Server Native Client 10.0][SQL Server]Invalid column name 'V__574.GISID'.] [InputFeatures]
The table was not found. [OutputFeatureClass]
If I run the tool in a model by itself, I get no errors, it's when I try to export the features to a feature class using "Copy Features" that I get the above error.
I am running version 10.2.2
Thanks for any insight in advance
Jeff Ward
Summit County GIS
Jeff Ward
Summit County, Utah
JeffWard
Honored Contributor
Julia at tech support was able to run the tool.  It turns out the query builder was adding double quotes around my fields, causing something to go wrong with the query.  If I remove the double quotes I am able to run the tool and get the results I need.
I will post further updates as I hear back from tech support
Jeff Ward
Summit County, Utah
SusanJones
Can you export your model to a python script and copy the code to another window?
It's heaps easier to troubleshoot that way.
curtvprice
Please post your query expression.
JeffWard
Honored Contributor
I ended up uninstalling 10.2.2 and reinstalling 10.2 and it worked.  Has anyone been able to run the Make Table Query in 10.2.2?
Jeff Ward
Summit County, Utah
SusanJones
ouch
MitchellWiniecki
I have not been able to successfully use this tool since upgrading to 10.2.2.  Just another problem in the LONG list of ESRI issues.  I never ceases to amaze me how a worldwide company can put out a product that simply doesn't work.
ESRI Premium Support < GIS Stack Exchange
JeffWard
Honored Contributor
I have submitted a support request.
Jeff Ward
Summit County, Utah
SusanJones
Good to know I am not the only one struggling to do this.
All I need to be able to hook up with database tables and publish them without needing to first register with ArcSDE and the Geodatabase.
Always worked Cool at ArcGIS 10.0 and ArcGIS 10.1 flavours.
JeffWard
Honored Contributor
Jeff Ward
Summit County, Utah
curtvprice
Be sure and post a bug # if you get one.
