Select features within selected polygon(s) not working
2714
09-29-2014 07:31 AM
RyanSellman
I am working on a sample that performs an attribute query on one layer and uses the results as geometry for a second query, which does a spatial intersect on another layer.  The first query works just fine but the second does not.  I get no errors in the console and when looking at the network traffic, the second query doesn't appear to be firing.  Can someone take a look at this and help?  Thanks in advance!!
Here's the fiddle!
RobertScheitlin__GISP
Ryan,
  Here is your sample with the results of the first query being unioned before the second query is executed. You may want to add some indication to the user that the union operation is occurring.
<!DOCTYPE html>
<html>
<head>
    <title>Spatial Query</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style>
        html,
        body,
        #mapDiv {
            padding: 0;
            margin: 0;
            height: 100%;
    </style>
    <script src="http://js.arcgis.com/3.10/"></script>
    <script>
        var map;
        require([
                "dojo/parser",
                "esri/geometry/Extent",
                "esri/graphicsUtils",
                "esri/SpatialReference",
                "dojo/on", "dojo/dom",
                "dijit/registry",
                "esri/tasks/FindTask",
                "esri/tasks/QueryTask",
                "esri/tasks/GeometryService",
                "esri/tasks/FindParameters",
                "esri/map",
                "esri/layers/ArcGISDynamicMapServiceLayer",
                "esri/InfoTemplate",
                "dojo/dom-construct",
                "esri/dijit/Popup",
                "esri/tasks/IdentifyTask",
                "esri/tasks/IdentifyResult",
                "esri/tasks/IdentifyParameters",
                "esri/dijit/InfoWindow",
                "esri/dijit/HomeButton",
                "esri/layers/FeatureLayer",
                "esri/toolbars/navigation",
                "esri/dijit/Legend",
                "esri/dijit/Print",
                "esri/dijit/BasemapToggle",
                "dojo/_base/array",
                "dijit/form/CheckBox",
                "dijit/form/NumberTextBox",
                "esri/dijit/BasemapGallery",
                "esri/dijit/Geocoder",
                "dojo/_base/Color",
                "esri/graphic",
                "esri/tasks/Geoprocessor",
                "esri/symbols/SimpleMarkerSymbol",
                "esri/geometry/screenUtils",
                "esri/dijit/Measurement",
                "esri/dijit/OverviewMap",
                "esri/dijit/Bookmarks",
                "esri/dijit/BasemapLayer",
                "esri/dijit/Basemap",
                "esri/dijit/BookmarkItem",
                "esri/units",
                "esri/geometry/Geometry",
                "esri/geometry/Point",
                "esri/geometry/Polyline",
                "esri/geometry/Polygon",
                "esri/dijit/Scalebar",
                "esri/dijit/AttributeInspector",
                "esri/symbols/SimpleLineSymbol",
                "dojo/query",
                "esri/symbols/SimpleFillSymbol",
                "esri/layers/ArcGISTiledMapServiceLayer",
                "esri/layers/ImageParameters",
                "esri/config",
                "esri/tasks/query",
                "esri/symbols/TextSymbol",
                "esri/renderers/SimpleRenderer",
                "esri/layers/LabelLayer",
                "dijit/form/Button",
                "dijit/form/ComboBox",
                "dijit/Dialog",
                "esri/toolbars/draw",
                "dijit/layout/BorderContainer",
                "dijit/layout/ContentPane",
                "dijit/layout/AccordionContainer",
                "dijit/layout/TabContainer",
                "dijit/layout/SplitContainer",
                "dojox/layout/ExpandoPane",
                "dojox/grid/DataGrid",
                "dojo/data/ItemFileReadStore",
                "dojo/domReady!"
            function(
                parser,
                Extent,
                graphicsUtils,
                SpatialReference,
                on,
                dom,
                registry,
                FindTask,
                QueryTask,
                GeometryService,
                graphicsUtils,
                FindParameters,
                Map,
                ArcGISDynamicMapServiceLayer,
                InfoTemplate,
                domConstruct,
                Popup,
                IdentifyTask,
                IdentifyResult,
                IdentifyParameters,
                InfoWindow,
                HomeButton,
                FeatureLayer,
                Navigation,
                Legend,
                Print,
                BasemapToggle,
                arrayUtils,
                CheckBox,
                NumberTextBox,
                BasemapGallery,
                Geocoder,
                Color,
                Graphic,
                Geoprocessor,
                SimpleMarkerSymbol,
                screenUtils,
                Measurement,
                OverviewMap,
                Bookmarks,
                BasemapLayer,
                Basemap,
                BookmarkItem,
                Units,
                Geometry,
                Point,
                Polyline,
                Polygon,
                Scalebar,
                AttributeInspector,
                SimpleLineSymbol,
                query,
                SimpleFillSymbol,
                ArcGISTiledMapServiceLayer,
                ImageParameters,
                esriConfig,
                Query,
                TextSymbol,
                SimpleRenderer,
                LabelLayer,
                Button,
                ComboBox,
                Dialog,
                Draw,
                BorderContainer,
                GeometryService,
                ContentPane,
                AccordionContainer,
                TabContainer,
                SplitContainer,
                ExpandoPane,
                DataGrid,
                ItemFileReadStore
                parser.parse()
                var twpQueryGraphic;
                map = new Map("mapDiv", {
                    center: [-81.646017, 41.100609],
                    zoom: 10,
                    basemap: "streets",
                var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://summitgis.summitoh.net:6080/arcgis/rest/services/DOES_Mercator/MapServer");
                map.addLayer(layer);
                var twpQueryTask = new QueryTask("http://summitgis.summitoh.net:6080/arcgis/rest/services/DOES_Mercator/MapServer/12");
                //build query filter
                var query = new Query();
                query.returnGeometry = true;
                query.where = "TYPE = 'TOWNSHIP'";
                query.outFields = ["*"];
                twpQueryTask.execute(query, function(featureSet) {
                    var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new dojo.Color([100, 100, 100]), 2), new dojo.Color([0, 0, 255, 0.20]));
                    for (var i = 0, il = featureSet.features.length; i < il; i++) {
                        //Get the current feature from the featureSet.
                        //Feature is a graphic
                        var graphic = featureSet.features;
                        graphic.setSymbol(symbol);
                        map.graphics.add(graphic);
                    var geomServ = new GeometryService("http://summitgis.summitoh.net:6080/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                    geomServ.union(graphicsUtils.getGeometries(featureSet.features),function(geom){
                      var plantQueryTask = new esri.tasks.QueryTask("http://summitgis.summitoh.net:6080/arcgis/rest/services/DOES_Mercator/MapServer/8");
                      var query2 = new esri.tasks.Query();
                      query2.returnGeometry = true;
                      query2.geometry = geom;
                      query2.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
                      plantQueryTask.execute(query2, showQueryTask2Result);
                      function showQueryTask2Result(featureSet2) {
                          console.log(featureSet2.features.length)
                          var symbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color("red"));
                          var resultFeatures = featureSet2.features;
                          for (var i = 0, il = featureSet2.features.length; i < il; i++) {
                              var graphic = featureSet2.features;
                    }, function(error){})
    </script>
</head>
<body class="claro">
    <div id="mapDiv"></div>
</body>
</html>
Ryan,
   Feature 0 of the first queries FeatureSet does not seem to have an intersecting point in your second query. If I change it to twpQueryGraphic = featureSet.features[5]; then I do get a point in the second query.
Ryan,
<!DOCTYPE html>
<html>
<head>
    <style>
        html,
        body,
        #mapDiv {
            padding: 0;
            margin: 0;
            height: 100%;
    </style>
    <script>
        var map;
        require([
                "dojo/parser",
                "dijit/registry",
                "esri/map",
                "esri/dijit/Popup",
                "esri/dijit/Print",
                "dojo/_base/array",
                "dojo/_base/Color",
                "esri/graphic",
                "esri/units",
                "dojo/query",
                "esri/config",
                "esri/tasks/query",
                "dijit/Dialog",
                "dojo/domReady!"
            function(
                parser,
                Extent,
                graphicsUtils,
                SpatialReference,
                on,
                dom,
                registry,
                FindTask,
                QueryTask,
                GeometryService,
                graphicsUtils,
                FindParameters,
                Map,
                InfoTemplate,
                domConstruct,
                Popup,
                IdentifyTask,
                IdentifyResult,
                IdentifyParameters,
                InfoWindow,
                HomeButton,
                FeatureLayer,
                Navigation,
                Legend,
                Print,
                BasemapToggle,
                arrayUtils,
                CheckBox,
                NumberTextBox,
                BasemapGallery,
                Geocoder,
                Color,
                Graphic,
                Geoprocessor,
                SimpleMarkerSymbol,
                screenUtils,
                Measurement,
                OverviewMap,
                Bookmarks,
                BasemapLayer,
                Basemap,
                BookmarkItem,
                Units,
                Geometry,
                Point,
                Polyline,
                Polygon,
                Scalebar,
                AttributeInspector,
                SimpleLineSymbol,
                query,
                SimpleFillSymbol,
                ImageParameters,
                esriConfig,
                Query,
                TextSymbol,
                SimpleRenderer,
                LabelLayer,
                Button,
                ComboBox,
                Dialog,
                Draw,
                BorderContainer,
                GeometryService,
                ContentPane,
                AccordionContainer,
                TabContainer,
                SplitContainer,
                ExpandoPane,
                DataGrid,
                ItemFileReadStore
                parser.parse()
                    zoom: 10,
                    basemap: "streets",
    </script>
</head>
</body>
</html>
RyanSellman
Robert,
Thanks so much for the response.  With your adjustments, the sample seems to be working like I want it to.
I appreciate your help!!
Ryan
