Javascript label graphic points
4806
09-29-2014 07:32 AM
deleted-user-yA_w_FC9FKe5
I have successfully been able to query my results and put them in a table and show them as points on my map thanks to a lot of help from these forums.
Now what I would like to do is create another graphics layer that just has labeling for these points but I am struggling with this.  I've searched endlessly for a way to do this.  I've looked through the samples I've found something called a labellayer but I don't know how to apply that.  I would think I would be able to use something like what I did for the graphics below but instead of a symbol use text.  I created a StoresResultsLayer_Labels as you can see below.  I'm sure this is simple but it is not for me for some reason.  Any help is greatly appreciated.
//My layers loaded at the start of the application but blank
StoresResultsLayer = new GraphicsLayer();
StoresResultsLayer.id = 'StoresResults';
map.addLayer(StoresResultsLayer,0);
StoresResultsLayer_Labels = new GraphicsLayer();
StoresResultsLayer_Labels.id = 'StoresResults_Labels';
map.addLayer(StoresResultsLayer_Labels,0);
//Some of my code from my function
var symbol = new esri.symbol.SimpleMarkerSymbol({
"color": [255,255,0,255],
"size": 11,
"xoffset": 1,
"yoffset": -2,
"type": "esriSMS",
"style": "esriSMSCircle",
"outline": {
"color": [0,0,0,255],
"width": 3,
"type": "esriSLS",
"style": "esriSLSSolid"  }});
   var dataForGrid = [];
var temp = "";
    //remove all graphics on the maps graphics layer
    StoresResultsLayer.clear();
     //Performance enhancer - assign featureSet array to a single variable.
     var resultFeatures = featureSet.features;
     //Loop through each feature returned
     for (var i=0, il=resultFeatures.length; i<il; i++) {
     //Get the current feature from the featureSet.
     //Feature is a graphic
     var graphic = resultFeatures;
     resultFeatures.setSymbol(symbol);
  StoresResultsLayer.add(resultFeatures);
  StoresResultsLayer.show();
by Anonymous User
Not applicable
Hi Michael -
It should in fact be pretty simple for you since you already have dealt with adding the graphics. You need to do 3 things: create a label renderer, create a label layer, and then add the features to the label layer. A lot of the information is here: labellayer-amd | API Reference | ArcGIS API for JavaScript.
// Make sure you include all of the modules here in your JavaScript 'require' function (e.g. 'esri/layers/LabelLayer',
// 'esri/symbols/TextSymbols' etc)
// Create label renderer
var labelParams = new TextSymbol({
        "type" : "esriTS",
        "color" : [0, 0, 153, 255],
        "font" : {
            "size" : 12,
            "style" : "normal",
            "weight" : "normal"
var labelRenderer = new SimpleRenderer(labelParams);
// Create the empty label layer
graphicsLabelLayer = new LabelLayer({
// Associate the label layer with the graphics you want to label
// Substitute in the field name you want to use to label your features
graphicsLabelLayer.addFeatureLayer(StoresResultsLayer , labelRenderer, '{field_name}');
by Anonymous User
Not applicable
Hi Michael -
        "type" : "esriTS",
        "font" : {
            "size" : 12,
            "style" : "normal",
            "weight" : "normal"
Hi Sarah and thanks for the quick reply.  I've tried messing around with your code  and this example:
Label Layer | ArcGIS API for JavaScript but for the life of me I can't get it working.  I wonder if it is because I am using a graphics layer and not a feature layer?
Basically I am filtering out a layer and then presenting the results as graphics.  I would then like to have labels for each of the graphics so they know the points name.  (StoreName) in this case.
This lead me in the right direction.  I just created another feature layer with opacity set to 00 and then used that to label.  Not the best of solutions but hey it works.
by Anonymous User
Not applicable
You know, in looking at the documentation it does seem to require a feature layer! I hadn't noticed that before, and I didn't test it, but I think you made the right call there.
