in a pyt (python toolbox): How do I make a boolean parameter default False???
7135
5
09-26-2014 06:42 AM
MartinHvidberg
In a .pyt I can define parameters as described in :
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
I have created a boolean parameter, the code snippet is as follow:
def getParameterInfo(self):
    """Define parameter definitions"""
    ... some other parameters ...
    # 3. Overwrite
    param3 = arcpy.Parameter(
        displayName="Overwrite Existing OBJ",
        name="Overwrite",
        datatype="GPBoolean",
        parameterType="Required",
        direction="Input")
The parameter works, but it anoys me that it defaults to True, I would like it to default to False.
v.h. Martin
TimothyHales
Esri Notable Contributor
You can set the default value by setting the value like this:
     name="Overwrite",
     direction="Input")
param3.value = "False"
TimothyHales
     name="Overwrite",
     direction="Input")
curtvprice
MVP Esteemed Contributor
Right on, Tim.
There are more details (and  examples) in the help page on this topic:
Defining parameters in a Python toolbox: ‌/ Setting default values for a parameter
Another wrinkle with booleans is the use of keywords, so the script tool's dialog box (and arcpy) will support a pick list of keywords.
From the same help page:
A Value List can be used for Boolean data types. For Boolean data types, the Value List contains two values: the true value and false value. The true value is always the first value in the list. These values are used in the command line for specifying the value.
param3.filter.list = ["OVERWRITE", "NO_OVERWRITE"]
param3.value = False
curtvprice
Timothy Hales‌ and Martin Hvidberg‌  - wondering about:
as Python bool ("False") is true (ie the string is "False" is non-empty so it is considered True in value. The parameter object may be converting it from "False" to False but I'd check to be sure.
TimothyHales
Valid concern there. I just tested this, and the string and the raw value both are seen correctly.
        param2 = arcpy.Parameter(
             displayName="False String",
             name="FalseString",
             direction="Input")
        param2.value = "False"
             displayName="False",
             name="False",
             direction="Input")
        param4 = arcpy.Parameter(
             displayName="True String",
             name="TrueString",
             direction="Input")
        param4.value = "True"
        param5 = arcpy.Parameter(
             displayName="True",
             name="True",
             direction="Input")
        param5.value = True
        params = [param2, param3, param4, param5]
        return params
curtvprice
def execute(self, parameters, messages):
    """The source code of the tool."""
    arcpy.AddMessage([k.value for k in parameters])
    return
Executing: Tool false false true true
Start Time: Mon Sep 29 16:09:23 2014
Running script Tool...
[False, False, True, True]
Completed script Tool...
Succeeded at Mon Sep 29 16:09:23 2014 (Elapsed Time: 0.00 seconds)
Yes, indeed, everything gets interpreted through its string representation, which I bet is case insensitive ("false" is interpreted by arcpy the same as "False")
