Remove values from Attribute
4149
09-27-2014 11:45 PM
MohammedKhamis
Dear All ,
Actually I need tool or model can remove specific values from attribute without remove columns , how can do that ??
anyone have idea about it , please help me ...
Note, on the attached picture to understand  me
thanks & regards,
MKN
XanderBakker
Esri Esteemed Contributor
Not sure why you want to do this...
It is possible to "hide" the column. This way the data remains, but is not visible. In case you don't want to keep the content of the column you can replace them with Null of blanks...
Kind regards, Xander
MohammedKhamis
Dear Xander,
thanks for your answer .
I need this tool because I working  with Juno (it is like garmin GPS of  collection data ) . I do check wells every day ,
I Entered data to Attribute by Juno and than sent them to SDE .
So when I send data to SDE , I need to Remove values attribute  from Juno to start again to check wells in next day ..
Is there tools or models like that ??
thanks
ParthaGhosh__GISP
This is the steps to replace any attribute value:
  1. Open attribute and select both line and column for the field to be deleted.1.jpg
  2. Right click on the selected column > Field Calculator > Field Calculator dialog comes up2.jpg
  4. Click OK
