Hillshade.java error messages
5490
22
09-22-2014 01:19 PM
FerasObeidat
hi all,
while start running HillshadeCommand in eclipse  I got these error messages, even-though there was no error in the code :
Starting HillshadeCommand - An ArcObjects SDK Developer Sample
java.lang.UnsatisfiedLinkError: no ntvinv in java.library.path
Could not load native libraries.
  at java.lang.ClassLoader.loadLibrary(Unknown Source)
  at java.lang.Runtime.loadLibrary0(Unknown Source)
  at java.lang.System.loadLibrary(Unknown Source)
  at com.esri.arcgis.interop.NativeLoader.loadLibrary(Unknown Source)
  at com.esri.arcgis.system.EngineInitializer.initializeEngine(Unknown Source)
  at HillshadeCommand.main(HillshadeCommand.java:45)
ShriramBhutada1
Hi Feras,
With help of one of my collegue, Kwasi A, I was able to run the sample successfully.. makes sure you have "C:\Program Files (x86)\ArcGIS\DeveloperKit10.2\java\samples\data\raster" folder on your system.
I'll send the zipped project as well.
Creating output directory - C:\Users\shri7493\arcgis_sample_output
Using default Azimuth value 315.0 and Altitude 45.0
Opening raster workspace C:\Program Files (x86)\ArcGIS\DeveloperKit10.2\java\samples\data\raster\dem1 and getting its dataset ...
Creating hillshade data ...
Done.  Output files created in C:\Users\shri\arcgis_sample_output\hillshadecommand
App Data = C:\Users\shri\AppData\Local
Log file path = C:\Users\shri\AppData\Local\ESRI\Engine10.2\Java\Log
ShriramBhutada1
Hi Feras,
Please look at the KB article
29348 - java.lang.UnsatisfiedLinkError: no ntvinv in java.library.path
The PATH variable does not include a directory which contains the native libraries required for ArcObjects Java classes to function.
Solution or Workaround
Add the directory that contains the native libraries needed by ArcObjects Java to the PATH variable.
  • On both Windows and Unix platforms, add either of the following directories to the PATH variable:
    A. $ARCENGINEHOME\java\jre\bin
    B. $ARCENGINEHOME\bin $ARCENGINEHOME may need to be replaced with the location of the ArcGIS SDK installation."
Shriram
FerasObeidat
Hi Shriram,
I updated the Path to include "C:\Program Files (x86)\ArcGIS\Desktop10.2\java\jre\bin"
But still the problem is not resolved, would you please elaborate more on it, I am new in this domain
Cheers,
Feras
ShriramBhutada1
Feras,
Sure. Hope this information is helpful.
First, please make sure you meet the system requirements System Requirements
ArcGIS for Desktop, ArcGIS Engine, or ArcGIS for Server is required to develop with ArcObjects SDK.
Java Development Kit (JDK) version 6. Update 20 and above are supported.
Second, make sure you are pointing to 32bit jre when using eclipse.
~Shriram
FerasObeidat
Hi Shriam,
This is what I have on my system related to ArcGIS:
- C:\Program Files (x86)\ArcGIS\Desktop10.2
- C:\Program Files (x86)\ArcGIS SDKs
Eclipse is working fine, as I tested it with other ArcGIS application (DrawingOverlayApp) and it works fine
ShriramBhutada1
Hi Feras,
Not sure of the exact problem. But at higher level, here is the direction I would go to troubleshoot the issue.
If the problem is not with the code, not the with java environment then I would say check the licenses. Seems like this sample requires 3d analyst extension - do you have those licenses available? Also if at all you are working data that is something you need to look at.
Shriram
FerasObeidat
I took the code from this site, I copied it into my Eclipse and just ran it. First there were problem highlighted in red and then I added the external libraries arcobjects.jar to get that resolved. Then, I simply run it and got the error. Yes I have the licence, how this can be used within the code? do you have other example that's working with a sample file.
Very much appreciated Shriram!
This the code which I copied:
/* Copyright 2012 ESRI
* All rights reserved under the copyright laws of the United States
* and applicable international laws, treaties, and conventions.
* You may freely redistribute and use this sample code, with or
* without modification, provided you include the original copyright
* notice and use restrictions.
* See the use restrictions.
package arcgissamples.analyst3d;
import java.io.File;
import java.io.IOException;
import com.esri.arcgis.datasourcesfile.TinWorkspaceFactory;
import com.esri.arcgis.datasourcesraster.DblPnt;
import com.esri.arcgis.datasourcesraster.Raster;
import com.esri.arcgis.datasourcesraster.RasterBand;
import com.esri.arcgis.datasourcesraster.RasterDataset;
import com.esri.arcgis.datasourcesraster.RasterWorkspace;
import com.esri.arcgis.datasourcesraster.RasterWorkspaceFactory;
import com.esri.arcgis.geoanalyst.RasterSurfaceOp;
import com.esri.arcgis.geodatabase.IGeoDataset;
import com.esri.arcgis.geodatabase.IPixelBlock;
import com.esri.arcgis.geodatabase.IRaster;
import com.esri.arcgis.geodatabase.IRasterDataset;
import com.esri.arcgis.geodatabase.IRasterProxy;
import com.esri.arcgis.geodatabase.Tin;
import com.esri.arcgis.geodatabase.esriRasterizationType;
import com.esri.arcgis.geodatabase.rstPixelType;
import com.esri.arcgis.geometry.Envelope;
import com.esri.arcgis.geometry.ISpatialReference;
import com.esri.arcgis.geometry.Point;
import com.esri.arcgis.system.AoInitialize;
import com.esri.arcgis.system.EngineInitializer;
import com.esri.arcgis.system.esriLicenseExtensionCode;
import com.esri.arcgis.system.esriLicenseProductCode;
import com.esri.arcgis.system.esriLicenseStatus;
public class HillshadeCommand {
  public HillshadeCommand(){
  * Main Method - The console application entry point.
  * @param args String[] Command line argument
  public static void main(String[] args) {
  System.out.println("Starting HillshadeCommand - An ArcObjects SDK Developer Sample");
   try{
   //Initialize engine console application
  EngineInitializer.initializeEngine();
   //Initialize ArcGIS license
  AoInitialize aoInit = new AoInitialize();
  initializeArcGISLicenses(aoInit);
   //Get DEVKITHOME Home
  String devKitHome = System.getenv("AGSDEVKITJAVA");
   //Data for an input Raster
   double azimuth = 315;
   double altitude = 45;
   //Data access setup
  String inDataPath = devKitHome + "java" + File.separator + "samples" + File.separator
  + "data" + File.separator + "raster";
  System.out.println(inDataPath);
  String inDataName = "dem1";
   //Data for an input TIN (swap the above code with this code to test with TIN input)
   //String inDataPath = arcGISHome + "java" + File.separator + "samples" + File.separator
   // + "data" + File.separator + "site1";
   //String inDataName = "dtm_tin";
   //Data output setup
  String outDataPath = getOutputDir() + File.separator + "hillshadecommand";
  String outDataName = "hillshade";
  File outData = new File(outDataPath);
   if (outData.exists()) {
  System.out.println("Output datafile already exists: " + outData.getAbsolutePath());
  System.out.println("Delete it and rerun.");
  System.out.println("Exiting...");
  System.exit(-1);
  }else{
  outData.mkdirs();
  System.out.println("Using default Azimuth value " + azimuth + " and Altitude " + altitude);
  HillshadeCommand hillshadeCommand = new HillshadeCommand();
  hillshadeCommand.createHillshade(inDataPath, inDataName, outData.getAbsolutePath(), outDataName, azimuth, altitude);
  System.out.println("Done. Output files created in " + outData.getAbsolutePath());
   //Ensure any ESRI libraries are unloaded in the correct order
  aoInit.checkInExtension(esriLicenseExtensionCode.esriLicenseExtensionCode3DAnalyst);
  aoInit.shutdown();
  }catch(Exception e){
  System.out.println("Error: " + e.getMessage());
  e.printStackTrace();
  System.exit(-1);
  * Checks to see if an ArcGIS Engine Runtime license or an Basic License
  * is available. If so, then the appropriate ArcGIS License is initialized.
  * @param aoInit The AoInitialize object instantiated in the main method.
  private static void initializeArcGISLicenses(AoInitialize aoInit) {
   try {
   if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeEngine)
  == esriLicenseStatus.esriLicenseAvailable)
  aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeEngine);
   else if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeBasic)
  aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeBasic);
   else{
  System.err.println("Could not initialize an Engine or Basic License. Exiting application.");
  System.exit(-1);
  aoInit.checkOutExtension(esriLicenseExtensionCode.esriLicenseExtensionCode3DAnalyst);
  } catch (Exception e) {e.printStackTrace();}
  * @param inDataPath - path to input data source
  * @param inDataName - name of input data source
  * @param outDataPath - path to output data source
  * @param outDataName - name of output data source
  * @param azimuth - angular direction of the sun, measured from north in clockwise
  * degrees from 0 to 360
  * @param altitude - the slope or angle of the illumination source above the horizon.
  * the units are degress from 0 (on the horizon) to 90 (overhead)
  * @throws Exception
  * @throws IOException
  private void createHillshade(String inDataPath, String inDataName, String outDataPath, String outDataName, double azimuth, double altitude) throws Exception {
   try {
   //Define raster workspace factory object
  RasterWorkspaceFactory rasWkspFactory = new RasterWorkspaceFactory();
   //Define tin workspace factory object
  TinWorkspaceFactory tinWkspFactory = new TinWorkspaceFactory();
   //Test what type of workspace we are dealing with. There are two possible
   //cases: 1. RasterWorkspaceFactory
   // 2. TinWorkspaceFactory
   //The first case handles raster workspace factories, while the second handles
   //tin workspace factories.
   if (rasWkspFactory.isWorkspace(inDataPath) && !tinWkspFactory.isWorkspace(inDataPath)){
   //Ouputting some useful information to let developer know which workspace
   //is being processed by the hillshade command
  File workspaceDir = new File(inDataPath, inDataName);
  System.out.println("Opening raster workspace " + workspaceDir.getAbsolutePath() + " and getting its dataset ...");
   //Get the raster workspace and it's dataset
  RasterWorkspace rasWksp = new RasterWorkspace(rasWkspFactory.openFromFile(inDataPath, 0));
  IRasterDataset iRasterDataset = rasWksp.openRasterDataset(inDataName);
   //Check if the raster is not of type RasterDataset
   if (!(iRasterDataset instanceof RasterDataset)) {
  System.out.println("The raster isn't a RasterDataset");
   throw new Exception();
   //Cast to RasterDataset
  RasterDataset inRasDataset = (RasterDataset) iRasterDataset;;
   //RasterSurfaceOp contains the hillshade command
  RasterSurfaceOp surface = new RasterSurfaceOp();
   //Create the hillshade data
  System.out.println("Creating hillshade data ...");
  IGeoDataset geoDataset = surface.hillShade(inRasDataset, azimuth, altitude, true, null);
   //Castto raster
  IRaster outRaster = new IRasterProxy(geoDataset);
   //Save the raster to disk
  saveGridToDisk(new Raster(outRaster), outDataPath, outDataName);
  }else if (tinWkspFactory.isWorkspace(inDataPath)){
  System.out.println(" " + workspaceDir.getAbsolutePath() + " is a valid Tin Workspace");
   //Instantiate a tin object
  Tin tin = new Tin();
   //Get a path to the source data including the file name
  String path = inDataPath + File.separator + inDataName;
  System.out.println(" Path to Tin: " + path);
   //Initialize the tin
  tin.init(path);
   //Use the tin's extent to get width and height of the Envelope
   //(i.e. Minimum bounding box)
  Envelope extent = (Envelope) tin.getExtent();
   double dx = extent.getWidth();
   double dy = extent.getHeight();
   //Determine the cell size
   double cellsize;
   if(dx > dy){
  cellsize = Math.round(dx/249);
  }else{
  cellsize = Math.round(dy/249);
   //Supported pixel types limited to float and long because
   //output currently limited to native ESRI Grid
  tinToRaster(tin, esriRasterizationType.esriHillShadeAsRaster, outDataPath, outDataName, cellsize, extent);
  }else{
  System.out.println("Program failed. Check input data path and name.");
  }catch (Exception e) {
   throw e;
  * Converts a tin to raster
  * @param tin
  * @param aRasterizationType
  * @param inDataPath
  * @param inDataName
  * @param cellsize
  * @param extent
  * @return
  private RasterDataset tinToRaster(Tin tin, int aRasterizationType, String inDataPath, String inDataName, double cellsize, Envelope extent) throws IOException {
  Point origin = (Point) extent.getLowerLeft();
  origin.setX(origin.getX() - (cellsize * .05));
  origin.setY(origin.getY() - (cellsize * .05));
   int nCol = (int)Math.round((extent.getWidth() / cellsize) + 1);
   int nRow = (int)Math.round((extent.getHeight() / cellsize) + 1);
  ISpatialReference spatialRef = tin.getSpatialReference();
  RasterDataset rasterDataset = createRasterDataset(inDataPath, inDataName, "GRID", origin, nCol, nRow, cellsize, cellsize, rstPixelType.PT_LONG, spatialRef, true);
  RasterBand rasterBand = (RasterBand) rasterDataset.item(0);
  Object nodataInt = rasterBand.getNoDataValue();
  DblPnt offset = new DblPnt();
   int mxblk_x = 2048;
   int mxblk_y = 2048;
   if(nCol < mxblk_x){
  mxblk_x = nCol;
   if(nRow < mxblk_y){
  mxblk_y = nRow;
  DblPnt blkSize = new DblPnt();
  blkSize.setX(mxblk_x);
  blkSize.setY(mxblk_y);
  Object blkArray;
  IPixelBlock pixelBlk = rasterBand.createPixelBlock(blkSize);
  blkArray = pixelBlk.getSafeArray(0);
  Point blkOrigin = new Point();
   for (int iRowOffset = 0; iRowOffset < nRow; iRowOffset = iRowOffset + mxblk_y) {
   for (int iColOffset = 0; iColOffset < nCol; iColOffset = iColOffset + mxblk_x) {
   if ((nCol - iColOffset) < mxblk_x) {
  blkSize.setX(nCol - iColOffset);
  blkOrigin.setX(origin.getX() + (iColOffset * cellsize) + (cellsize * 0.5));
  blkOrigin.setY(origin.getY() + ((nRow - iRowOffset) * cellsize) - (cellsize * 0.5));
  tin.queryPixelBlock(blkOrigin.getX(), blkOrigin.getY(), cellsize, cellsize, aRasterizationType, nodataInt, blkArray);
  offset.setX(iColOffset);
  offset.setY(iRowOffset);
  rasterBand.write(offset, pixelBlk);
   boolean reset = false;
   if (!(blkSize.getX() == mxblk_x)){
  reset = true;
   if ((nRow - iRowOffset) < mxblk_y){
  blkSize.setY(nRow - iRowOffset);
   if (reset){
   return rasterDataset;
  * Create a raster dataset
  * @param inDataPath
  * @param inDataName
  * @param format
  * @param origin
  * @param nCol
  * @param nRow
  * @param cellsizeX
  * @param cellsizeY
  * @param ePixelType
  * @param spatialRef
  * @param permanent
  * @return
  private RasterDataset createRasterDataset(String inDataPath, String inDataName, String format, Point origin, int nCol, int nRow, double cellsizeX, double cellsizeY, int ePixelType, ISpatialReference spatialRef, boolean permanent) throws IOException {
  RasterWorkspaceFactory rasterWorkspaceFactory = new RasterWorkspaceFactory();
  RasterWorkspace rasterWorkspace = new RasterWorkspace(rasterWorkspaceFactory.openFromFile(inDataPath, 0));
   int numbands = 1;
  RasterDataset rasterDataset = (RasterDataset) rasterWorkspace.createRasterDataset(inDataName, format, origin, nCol, nRow, cellsizeX, cellsizeY, numbands, ePixelType,spatialRef, permanent);
  * Saves a raster to disk
  * @param raster - input raster
  * @param outDataName - name of input data source
  private void saveGridToDisk(Raster raster, String outDataPath, String outDataName) throws IOException {
   try {
   //Obtain a raster workspace factory object
   //We can safely assume that this is RasterWorkspace based on the conditional
   //testing done in the createHillshade().
  RasterWorkspace rasterWorkspace = new RasterWorkspace(rasWkspFactory.openFromFile(outDataPath, 0));
  raster.saveAs(outDataName, rasterWorkspace, "GRID");
  } catch (IOException e) {
  System.out.println("Could not save raster as grid data to disk.");
   throw e;
  * Convenience method to generate an output directory based on the operating
  * system that the sample is being executed on.
  * @return A path to the new directory is return
  private static String getOutputDir() {
  String userDir;
   //Get the operating systems user profile or home location depending
   //on which operating system this sample is executed on.
   if(System.getProperty("os.name").toLowerCase().indexOf("win") > -1){
  userDir = System.getenv("UserProfile");
  }else{
  userDir = System.getenv("HOME");
  String outputDir = userDir + File.separator + "arcgis_sample_output";
  System.out.println("Creating output directory - " + outputDir);
   new File(outputDir).mkdir();
   return outputDir;
FerasObeidat
Hello Shriram,
I would be grateful if you can send me all steps that are required to run HillshadeCommand.java from eclipse .
However, I was successfully able to run the following class in java through eclipse:  DrawingOverlayApp.java
But still having problem to run HillshadeCommand, I think it will good to start all steps from beginning so I avoid missing any thing? any help ?!
Feras
ShriramBhutada1
Hi Feras,
I typically work more with .NET Arcobjects rather than on Java Arcobjects. Having said that, I'll see what I can do about it.
Btw - do you have ESRI technical support account?
Regards,
Shriram B
FerasObeidat
Hi Shriram,
No, I don't have ESRI technical support account.
Thanks for help in advance!
Feras
