Disable Editing on Certain Attributes
3404
09-22-2014 01:26 PM
JessicaLott
Is there a way in ArcGIS Online to make it where only certain attributes can be edited? We get our data into ArcGIS online through the use of .csv files.
Thank you for your help.
AnthonyGiles
Honored Contributor
Jessica,
I think this can be done through the pop up configuration:
'You can configure pop-ups in ArcGIS Server service layers, hosted feature layers, hosted tile layers, and layers from files. If you are configuring pop-ups for an ArcGIS Server feature layer, you can also set which fields are editable.'
not sure if this will work against a csv or if it's only available for a feature service.
Configure pop-ups—Help | ArcGIS
regards
Anthony
AnthonyGiles
Honored Contributor
Jessica,
regards
Anthony
JessicaLott
Yes! I actually found this answer through another discussion this morning. For some reason I could not find the answer through a Google search. Thanks for your help!!
