export and import
1591
09-19-2014 01:09 AM
MassimoSpirlandelli
I'm new in Collector for ArcGis...
Is it possible to build a shp file based on my needs for collect data in Collector for ArcGis? If no is it possible can I do the same work in other way?
Is it possible use a own map as a basemap (for example a cadastral map) upload on my smartphone? If yes, how?
Once you have collected data on field is it possible export the data in shp or table format or somehow?
If is possible download the data you have collected on field in which coordinate system are they?
thank you
