IdentifyParameters fail
4165
09-17-2014 09:24 AM
NadirHussain
identifyParams.tolerance = 3;
                            identifyParams.returnGeometry = true;
                            identifyParams.layerIds = [0, 1, 2, 3, 4, 5];
                           identifyParams.geometry = point;
                            identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
                            identifyParams.width = map.width;
the redline fail.It give the message.cannot read property 'geometry' undefined  .
please what should be the reason.Thanks in advance.
KenBuja
MVP Esteemed Contributor
In your code, "point" is a variable. How have you created it?
This is how it's done in a sample
map.on("click", doIdentify);
function doIdentify (event) {
            map.graphics.clear();
            identifyParams.geometry = event.mapPoint;
            identifyParams.mapExtent = map.extent;
            identifyTask.execute(identifyParams, function (idResults) {
              addToMap(idResults, event);
NadirHussain
function myClickHandler(evt) {
                try {
                    if (identfyFlag == 1) {
                        var point = evt.mapPoint;
                        SMS.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
                        SMS.setSize(12);
                        SMS.setColor(new esri.Color([255, 0, 0, 0.5]));
                        identifyTask = new IdentifyTask("http://dell-pc/ArcGIS/rest/services/Sirens/MapServer");
                        identifyParams = new IdentifyParameters();
                        if (identifyParams != null) {
                                   identifyParams.Geometry = point;
                                  identifyParams.height = map.height;
                        var pointGraphic = new Graphic(point, SMS);
                        map.graphics.add(pointGraphic);
                        idResults = new IdentifyResult();
                        processIdentifyResults(point)
                } //try
                catch (err) {
                    txt = "There was an error on this page.\n\n";
                    txt += "Error description: " + err.message + "\n\n";
                    txt += "Click OK to continue.\n\n";
                    alert(txt);
Dear ken thanks for reply. my complete code is above.i passed the event mapPoint to the point variable.
KenBuja
Remember that Javascript is case sensitive. The line
should be
Why are you using this if statement?
The way your code is written, this will always be true
NadirHussain
                try {
                        SMS.setSize(12);
                    }//if
                } //try
                catch (err) {
                    alert(txt);
dear ken,
i update the code.but same error is coming.i am confused.please help
