Setting Address Locator properties using ArcObjects
3418
09-17-2014 09:05 AM
GeoDecisionsEDN9GannettFleming
I am creating an Address Locator using ArcObjects and assigning properties to it, primarily through the IGeocodingProperties2 interface.  I cannot find how to set two properties - “write locator specific output fields” and “write display extent output fields" - these do not seem to be exposed by this or any other interface
In the ArcMap GUI, you can set them under Address Locator -> Properties -> Outputs, as shown in the image below
My locator creation code is straightforward.  It expects the feature dataset (featureDataset below) and featureclass (featureClass below) where reference data is stored - to be already known:
            IWorkspace workspace  = featureDataset.Workspace;
            // Open the database locator workspace for the ArcSDE workspace.
            System.Object obj = Activator.CreateInstance(Type.GetTypeFromProgID("esriLocation.LocatorManager"));
            ILocatorManager2 locatorManager2 = obj as ILocatorManager2;
            ILocatorWorkspace locatorWorkspace = locatorManager2.GetLocatorWorkspace(workspace);
            // Get the Locator Style from the client workspace
            ILocatorWorkspace clientLocatorWorkspace = locatorManager2.GetLocatorWorkspaceFromPath("");
            ILocatorStyle locatorStyle = clientLocatorWorkspace.GetLocatorStyle("US Address - Dual Ranges");
            // Given the featureclass holding the reference data.
            IDataset dataset = (IDataset) featureClass;
            IReferenceDataTables referenceDataTables = (IReferenceDataTables) locatorStyle;
            IEnumReferenceDataTable enumReferenceDataTable = referenceDataTables.Tables;
            enumReferenceDataTable.Reset();
            IReferenceDataTable referenceDataTable = enumReferenceDataTable.Next();
            IReferenceDataTableEdit referenceDataTableEdit = (IReferenceDataTableEdit) referenceDataTable;
            referenceDataTableEdit.Name_2 = (ITableName) dataset.FullName;
            // Store the locator if the reference data is properly specified.
            ILocator locator = null;
            if (referenceDataTables.HasEnoughInfo)
                string targetLocatorNameString = "Loc01";
                locator = locatorWorkspace.AddLocator(targetLocatorNameString, (ILocator)locatorStyle, "", null);
                // Set the custom geocoding properties.
                //Write locator-specific output fields : Yes, Return display extent output fields : Yes
                IGeocodingProperties2 geocodingProperties2 = locator as IGeocodingProperties2;
                geocodingProperties2.AddXYCoordsToMatchFields = true;
                geocodingProperties2.MinimumCandidateScore = 10;
                geocodingProperties2.SideOffset = 10;
                geocodingProperties2.EndOffset = 10;
                locatorWorkspace.UpdateLocator(locator);
Any code samples would help.
Thanks!
Tags (3)
BradNiemand
You would do it in the following way if you want to do it at runtime:
        ILocatorImpl locatorImpl = locator as ILocatorImpl;
        IPropertySet locatorProperties = locatorImpl.Properties;
        locatorProperties.SetProperty("WriteDisplayExtentFields", "True");
        locatorProperties.SetProperty("WriteLocatorSpecificFields", "True");
        locatorImpl.Properties = locatorProperties;
If you want to do it to the locator and keep them updated, you can modify the .loc file directly using a text ediitor.
Brad
