Geocoder dijit throws error on submit when autocomplete is true - bug?
3014
09-15-2014 06:48 AM
JuliaCarney
When autocomplete is enabled for the geocoder widget, if a user choses to press enter instead of selecting from the autocomplete drop-down, it throws the following error:
Error "Error: This deferred has already been resolved
    at Error (native)
    at d (http://js.arcgis.com/3.10/init.js:73:478)
    at resolve.callback (http://js.arcgis.com/3.10/init.js:75:350)
    at q._receivedResults (http://js.arcgis.com/3.10/js/esri/dijit/Geocoder.js:31:116)
    at null.<anonymous> (http://js.arcgis.com/3.10/js/esri/dijit/Geocoder.js:28:18)
    at http://js.arcgis.com/3.10/init.js:174:23
    at c (http://js.arcgis.com/3.10/init.js:74:221)
    at d (http://js.arcgis.com/3.10/init.js:74:10)
    at null.<anonymous> (http://js.arcgis.com/3.10/init.js:754:70)"
This is the case even in your sample at this url: Geocoder Widget | ArcGIS API for JavaScript . Is there a workaround or patch for this? Is there a way to disable whatever event (submit or keyup?) is triggering it?
Jules
