MGRS Geocoder Issue
5304
8
09-12-2014 07:38 AM
StevenGraf1
I'm trying to use the custom geocoder widget to zoom to a USNG coordinate and not having much luck.  It keeps throwing an init.js error.
I am using the custom geocoder widget that I modified slightly.  I thought maybe I need to project the map to the same spatial reference as the geocoder so i added that in.
Here is a fiddle: Edit fiddle - JSFiddle
Thanks!
TimWitt2
Steven,
try this:
<!DOCTYPE html>
<html>
  <head>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <title>Geocoder Widget</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
      #searchbox {
        display: block;
        position: absolute;
        z-index: 2;
        top: 20px;
        left: 75px;
    </style>
    <script src="http://js.arcgis.com/3.9/"></script>
    <script>
      var map;
      var geocoder;
      require([
        "esri/map", "esri/dijit/Geocoder", "esri/SpatialReference", "dijit/form/TextBox", "dojo/parser",
  "esri/tasks/locator", "dojo/on", "dojo/dom", "dijit/registry", "dijit/form/Button" ,"dojo/domReady!"
      ], function(
        Map, Geocoder, SpatialReference, TextBox, parser, Locator, on, dom, registry
  parser.parse();
  var locatorUrl = "http://serverapps101.esri.com/arcgis/rest/services/MGRS/GeocodeServer";
  var Gridlocator = new Locator(locatorUrl);
  var locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
    var spatialReference = new SpatialReference({wkid:4326});
        map = new Map("map",{
          basemap: "topo",
          center: [-117.19,34.05], // lon, lat
          zoom: 13,
  spatialReference: spatialReference
  var GridTextBox = new TextBox({
  placeHolder: "18SUJ23480647",
  value:"18SUJ23480647"
  },"GridTextBoxDiv");
  on(registry.byId("grid"), "click", setgrid);
  function setgrid (){
  var GridPoint = registry.byId("GridTextBoxDiv").get("value");
  var gridnmb = {MGRS:GridPoint};
  Gridlocator.addressToLocations(gridnmb);
  map.graphics.clear();
  Gridlocator.on("address-to-locations-complete", locateMeGridAddress);
  function locateMeGridAddress(evt){
  var FoundPointAr = evt.addresses;
  var FoundPoint = FoundPointAr[0];
  var LocPoint = FoundPoint.location;
  map.centerAndZoom(LocPoint);
    </script>
  </head>
  <body class="claro">
    <div id="map">
  <div id="searchbox"><input id="GridTextBoxDiv"/><button id="grid" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button">Get Location</button> </div>
  </div>
  </body>
</html>
Tim
TimWitt2
Maybe this can help?
Javascript API - Location Widget
StevenGraf1
That's where I started at first and was able to pull out the zoom to usng part of it, but it was still throwing me an error although working at the same time.  I don't remember if I saved the error as it was a few weeks ago.
I decided to see if I could get the customer geocoder widget to work with the MGRS geocoder because that's the only aspect of your fiddle that I need.
Thanks!
TimWitt2
Ah I see. Let me see if I can fix it.
TimWitt2
Steven,
do you need to do it through the geocoder or can you do it through a textbox like i have it?
Tim
StevenGraf1
Either way would be fine.
Thanks for your help!
TimWitt2
Steven,
try this:
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        overflow:hidden;
      #searchbox {
        display: block;
        position: absolute;
        z-index: 2;
        top: 20px;
        left: 75px;
    </style>
    <script>
      var map;
      var geocoder;
      require([
      ], function(
  parser.parse();
          basemap: "topo",
          zoom: 13,
    </script>
  </head>
    <div id="map">
  </div>
  </body>
</html>
Tim
StevenGraf1
Thanks so much!
So basically you are just passing a string through a text box on to the locator?
Any reason you can think of that the geocoder wouldn't work?
TimWitt2
Yes thats right.
I have no idea why the geocoder would not be working, When I use the debugger it does not return anything after I run the geocoder.
