Customizing the Measurement tool (Javascript)
2946
09-11-2014 01:04 PM
WorkPlayce
I need a tool much like the Measurement tool, which
1) allows user to draw a polygon
2) depending on which feature layers are visible on the map
3) query the feature layers with custom sql to return a count (sum)
4) display this result
Seems like if can:
1) Modify the Measurement tool to add an additional unit of measure
2) Intercept the measure event to reroute it as a sql against a featurelayer or featurelayers
3) When the result of query returns, use the value(s) to set the display on the Measurement tool
Is this possible with the existing API?
If not is there a way to get access to the widget source code?
RiyasDeen
Hi Work,
I don't know your exact use case, but you can achieve this without extending measurement widget. Consider below
Use Draw toolbar to capture user polygon. draw-amd | API Reference | ArcGIS API for JavaScript
Get Visible layer Ids arcgisdynamicmapservicelayer-amd | API Reference | ArcGIS API for JavaScript
Use Query for count in query task to get your count querytask-amd | API Reference | ArcGIS API for JavaScript
WorkPlayce
Sorry,
Requirements have changed. I need to create a Query task for selection.
I have done this and the query returns with list of selected objects, but the features are not being highlighted.
ArcGIS Javascript API says:
Selects features from the FeatureLayer. Layer properties like layer definition and time definition are honored. The selection method defines how query results are passed to the selection. The feature layer will highlight the current selection if a selection symbol has been defined. Whenever possible, the feature layer will perform the query operation on the client (browser).
Do I need to define selection symbols on the featurelayer?|
Do you have any code snippets?
Thanks.
RiyasDeen
Hi Work,
Yes you have to set selection symbol. featureLayer.setSelectionSymbol(symbol);
Check out this sample. Select with Feature Layer | ArcGIS API for JavaScript
