Needing Help with ArcObjects Program, Programming Several Checkboxes to one Combobox
2063
09-11-2014 12:07 PM
MichelleCouden1
I have attached a picture of my GUI. So when you look at the GUI you'll notice the combobox with Abilene in it, then look to the right and you will see several checkboxes. This is how I need it to work. They select a District i.e. Abilene, then they can check as many boxes as they want for the stations they want in their map. For Example, Abilene is the district and then they want ATR, AVC, BC, and LTPP stations. I have code written below please let me know if this is the right path or is there a shorter way to program this GUI.
Private Sub CmdMap_Click ()
Dim pGxLayer As IGxLayer
Set pGxLayer1 = New GxLayer
Dim pGxFile1 As IGxFile
Set pGxFile1 = pGxLayer1
     If cboDistrict.Text = "Abilene" Then
          If ChkAtr.Text = True Then
               pGxFile1.Path = "K:/permanentstations/Atr.lyr
          ElseIf ChkAvc.Text = True Then
               pGxFile1.Path = "K:/permanentstations/Avc.lyr
           ElseIf ChkBc.Text = True Then
               pGxFile1.Path = "K:/permanentstations/Bc.Lyr
[\\CODE]
Tags (1)
