Needing Help with ArcObjects Program, Programming Several Checkboxes to one Combobox
4572
09-10-2014 01:51 PM
MichelleCouden1
I have attached a picture of my GUI. So when you look at the GUI you'll notice the combobox with Abilene in it, then look to the right and you will see several checkboxes. This is how I need it to work. They select a District i.e. Abilene, then they can check as many boxes as they want for the stations they want in their map. For Example, Abilene is the district and then they want ATR, AVC, BC, and LTPP stations. I have code written below please let me know if this is the right path or is there a shorter way to program this GUI.
Private Sub CmdMap_Click ()
     If cboDistrict.Text = "Abilene" Then
          If ChkAtr.Text = True Then
               pGxFile1.Path = "K:/permanentstations/Atr.lyr
          ElseIf ChkAvc.Text = True Then
               pGxFile1.Path = "K:/permanentstations/Avc.lyr
[\\CODE]
KenBuja
MVP Esteemed Contributor
Could you provide a slightly longer code fragment, showing a few cities and their possible paths?
Also, you should move this discussion to the ArcObjects space to get more focused attention on this question.
MichelleCouden1
Ken, I moved it to ArcObjects space. Let me know if I made any mistakes. Also, I added all the code that I have at this time.
