populate field attributes in dojo combobox
5318
09-10-2014 05:09 PM
RichardMoussopo
I would like to populate field attributes in dojo combobox and zoom to the selected feature on selected Index changed. any way to achieve this?
RobertScheitlin__GISP
Richard,
  Here is a thread that answers this question with sample code https://community.esri.com/message/399170#399170
Richard,
RichardMoussopo
Thank you Robert the link was very helpful. But, now I am having a little issue.
In my case, I have 3 comboboxes populated from 3 different layers and I would like to use the same function (app ={
      zoomRow:
for all 3 comboboxes. I thought about using the switch case depending on the ComboBox id but no success.
is there a way around this?
Richard,
  Here is a sample that show how to reuse the zoomRow for two different comboboxes:
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Drop Down Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script src="http://js.arcgis.com/3.10/"></script>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/on",
      "esri/tasks/query",
      "esri/layers/FeatureLayer",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/json",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/form/Button",
      "dijit/form/ComboBox",
      "dojo/domReady!"
    ], function(
      Map, on, Query, FeatureLayer, Memory, array, lang, esriRequest, json
      map = new Map("map", {
        basemap: "topo",
        center: [-120.1883, 37.0868],
        zoom: 6
      var zipcodes = new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/california-zip-codes-census-2010/Fe...", {
        mode: FeatureLayer.MODE_SELECTION,
        outFields: ["*"]
      map.addLayers([zipcodes]);
      map.on("layers-add-result", lang.hitch(this, function(){
        var url = "http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/california-zip-codes-census-2010/Fe...";
        var classificationDef = {"type":"uniqueValueDef","uniqueValueFields":["ZCTA5CE10"]};
        var classificationDef2 = {"type":"uniqueValueDef","uniqueValueFields":["GEOID10"]};
        var str = json.stringify(classificationDef);
        var str2 = json.stringify(classificationDef2);
        esriRequest({
          url:url,
          content:{
            classificationDef:str,
            f:'json'
          handleAs:'json',
          callbackParamName:'callback',
          timeout:15000
        }).then(lang.hitch(this,function(response){
          var uniqueValueInfos = response && response.uniqueValueInfos;
          if(uniqueValueInfos){
            var store2 = new Memory({data:[]});
            dijit.byId("uniqueValuesSelect").set('store',store2);
            var data = array.map(uniqueValueInfos,lang.hitch(this,function(info,index){
              var value = info.value;
              value = parseFloat(value);
              var dataItem = {
              return dataItem;
            store2 = new Memory({data:data});
        }),lang.hitch(this,function(error){
          console.error(error);
        esriRequest({
          url:url,
          content:{
            classificationDef:str2,
            f:'json'
          handleAs:'json',
          timeout:15000
          var uniqueValueInfos2 = response && response.uniqueValueInfos;
          if(uniqueValueInfos2){
            var store3 = new Memory({data:[]});
            dijit.byId("uniqueValuesSelect2").set('store',store3);
            var data2 = array.map(uniqueValueInfos2,lang.hitch(this,function(info,index){
              var value2 = info.value;
              //value2 = parseFloat(value2);
              var dataItem2 = {
              return dataItem2;
            store3 = new Memory({data:data2});
      app = {
        zoomRow: function(id, which){
          zipcodes.clearSelection();
          var query = new Query();
          if(which == "zip"){
            query.where = "ZCTA5CE10='" + (id).toString() + "'";
          }else if(which == "geo"){
            query.where = "GEOID10='" + (id).toString() + "'";
          console.info(query.where);
          query.returnGeometry = true;
          zipcodes.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
            var thePoly = features[0].geometry;
            var theExtent = thePoly.getExtent().expand(2); //Zoom out slightly from the polygon's extent
            map.setExtent(theExtent);
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="overflow:hidden;border:none;border-bottom: 3px solid #CC9900;font-family: Windows;font-size:14pt; color: #FFFFFF;background: #000000; "> Select a California Zip Code and zoom to it on the map:
      <input id="uniqueValuesSelect" data-dojo-type="dijit.form.ComboBox" value="Zipcode" onchange="app.zoomRow(document.getElementById('uniqueValuesSelect').value, 'zip');" />
      <input id="uniqueValuesSelect2" data-dojo-type="dijit.form.ComboBox" value="GEOID10" onchange="app.zoomRow(document.getElementById('uniqueValuesSelect2').value, 'geo');" />
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:95%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
