Double click does not end measure tool in basic viewer IE only
1073
09-10-2014 08:47 AM
ChrisDalla_Piazza
A while back we put together a web map by customizing the basic viewer template that was available at the time.  I guess enough time has gone by that it is now the "classic viewer" http://www.arcgis.com/apps/OnePane/basicviewer/index.html
When I use the measure tool to lay down some points for either the distance or area, I can't end the line segments or close the polygon by double clicking.  I just keeps putting down points.  This is in IE only.
The problem does not appear in the basic template linked above.  I noticed that the template linked above uses version 3.10 of the JavaScript API.  The template that we customized uses 3.6.  I did attempt a quick upgrade to 3.10.  That did fix the problem but it created new problems.  Starting over again with the linked template and re-customizing would be time prohibitive.
Anybody know how to fix this and stay on version 3.6 of the API?
