JavaScript Refresh credential and prevent Identity Manager pop-up
4583
09-09-2014 02:24 PM
BlairJones
I want to use tokens with a short expire time,  generate a new token before expire, and then replace credentials for layers in a map.
My problem is how to prevent ArcGIS Identity Manager from continuing to create a pop-up requesting credentials.
I start with dom.byId('tokenText').value as a token having a short expire time.  I start a JavaScript timer giving 30 seconds to create a new token.
I try to update credentials; I'm not sure I know what I'm doing...  Pop-ups from Identity Manager occurs anyway.
Here is the "guts" of my work;  any suggestions will be cheerfully accepted!
var tokenText,layerSource;
ready(function() {
function renewToken(urlOfMapService){
    xhr.get({
// The URL of the request
        url: "refreshToken.aspx",
// Allow 10 seconds to get new token
        timeout: 10000,
// Send the existing token
        content: {
            token: tokenText
// The success callback with result from server
        load: function(result) {
//--- result is a Comma Separated Value string of creatTime, expireTime, tokenText
            var dataArray = result.split(',');
            dataArray.push(urlOfMapService);
//--- UPDATE CREDENTIALS
            initializeCredentials( dataArray );
            app.map.getLayer("Warblers").credential = credential;
// The error handler
        error: function(message) {
            alert("error:"+message);
function initializeCredentials(a) {
//--- a is Array  of creatTime, expireTime, tokenText, resourceURL
//--- call renewToken before expire
    waitTime = parseInt(a[1],10)
        - parseInt(a[0],10)
        - 30000;
    credentialsTimer = setTimeout(function(){renewToken(DGIFData)}, waitTime );
//--- fwisCredentials is a global Object variable assigned using JSON in a loaded script
    tokenText = a[2];
    credential = fwisCredentials.credentials[0];
    credential.creationTime = a[0];
    credential.expires = a[1];
    credential.token = tokenText;
    credential.resources.push(a[3]);
    fwisCredentials.credentials = [credential];
    kernel.id.initialize(fwisCredentials);
esri.config.defaults.io.proxyUrl = "https://my.server.com/proxypage_net/proxy.ashx";
    layerSource = "https://my.server.com/arcgis/rest/services/Test/Warblers/MapServer";
//--- initial token  and times are available at ready event
    tokenText = dom.byId('tokenText').value;
    initializeCredentials( [
        dom.byId('tokenCreateTime').value,
        dom.byId('tokenExpireTime').value,
        tokenText,
        layerSource
    app.map = new esri.Map("map", {
        center: [-78.839150, 38.061840],
        zoom: 7,
        basemap: "topo",
        slider: true,
        showAttribution:true,
        logo: false,
        autoResize: true
//===LAYER LIST AND MAP SERVICES=======================================================================================
    var layerObject = new ArcGISDynamicMapServiceLayer(layerSource,
       { id: "Warblers", opacity: .8 });
    var flRegions = new FeatureLayer("https://my.server.com/arcgis/rest/services/Public/Agency_Public/FeatureServer/9", {
        mode: FeatureLayer.MODE_ONDEMAND
    app.map.addLayers([flRegions, layerObject]);
  });  // ready function end
Tags (1)
BlairJones
Thanks Kelly,
I have looked again at the proxy program code and I understand  that the proxy is used to fetch each map tile and
a new token is created and tried when the server request returns an error.
In trying to understand ArcIS API with regard to credentials, I am trying to update within the client web page.
The "simple" solution I have found using only ArcGIS JavaScript API is to:
0)   not use credential objects and not use kernel.id.initialize()
1)  add a new layer
var tokenText = aGoodTokenString;
var layerObject = new ArcGISDynamicMapServiceLayer(urlOfMapService + "?token=" + tokenText
           ,{   id: layerID  });
app.map.addLayers([layerObject]);
2) using setTimeout()
     update the layer.url with a new token string:
     tokenText = createNewTokenStringPrivateFunction(tokenText);
     map.getLayer(layerID).url = urlOfMapService + "?token=" + tokenText;
There is already an instance of the proxy running on my ArcGIS server.  I am gathering client name and password from another independent web server.  The generated client web page does not have username and password to pass to the proxy.
I now have a choice to either modify the proxy for my needs, use client side JavaScript to renew the url directly, or both.
KellyHutchins
Esri Notable Contributor
The existing Esri/resource-proxy · GitHub  handles this work for you. You just setup the proxy.config file with the url to the service along with the username and password used to generate the token. The proxy will use the provided credentials to get the token and will request a new token when needed.
BlairJones
Thanks for your suggestion.  I understand this proxy will provide a usable token when initially adding a resource to the map object.  I may be dense, but how does using this proxy prevent the Identity Manager authorization dialog from poping-up when the token expire time occurs during a client web session?
Before expire time I can use map.removeLayer() followed by map.addLayer() with a new token, but the results are ugly.
kernel.id.initialize() works similar to supplying a first token appended to the layer url,  but I can find no documentation for kernel.id
I found property layer.credential in the ESRI web based API descriptions, but I find layer.credential is not assigned by map.addLayer() and anything I place into layer.credential is ignored.
KellyHutchins
Blair,
Let me make sure I understand your scenario. Are you currently having users log-in to your application with the Identity Manager? If so then the IM should handle getting new tokens if the existing one expires.
If you are not asking users to log-in to access secure services but are generating the token based on stored credentials the proxy will take care of generating a new token when the existing one expires.
BlairJones
Thanks Kelly,
1)  add a new layer
           ,{   id: layerID  });
