Geoprocessing output schema for Silverlight Viewer
2243
09-09-2014 03:13 PM
ElliottCarson
I've created a working ArcGIS Server geoprocessing tool. It works as expected in ArcMap, it will output the appropriate feature and attribute table schema base on the selected layer by the user.
When I added the same tool to the Silverlight Viewer I get the expected feature, however the attribute table schema is only relevant to the default layers schema at the time of publishing.
Is this always the case, or have I missed something when adding the tool to the viewer?
Thanks for any help,
Elliott
ElliottCarson
The schema output is locked for server geoprocessing tools, it is based on the original schema at the time of publishing. Expect no change for the 10.3.
Regards,
Elliott
ElliottCarson
Regards,
Elliott
