ArcGIS Javascript API and Dojo version
1784
09-09-2014 05:43 AM
PeterLen
Hello - I had a quick question which i can't seem to find the answer for.  We are using ArcGIS 10.0 and from that, we are using the ArcGIS Javascript API v2.2 which includes the Dojo API v1.5.0.  What I am trying to figure out is a two-part questions:
1)  Is there some list that states what versions of the ArcGIS Javascript API contain which versions of the Dojo API?
2)  Is a given version of the ArcGIS Javascript API dependent on the version of ArcGIS?  For example, If I donwloaded the newest version of the Javascript API, would it work with ArcGIS 10.0?
The reason I ask this is that I need to find which ArcGIS Javascript API version contains Dojo v1.6.x.  I realize that Dojo is up to v1.10 but I cannot move up to Dojo v1.7 due to its upgrade to use AMD (our app would have to be converted).  I need the Dojo v1.6.x to get the most stable version of the TreeGrid object before the v1.7 release.  So, the bottom line, is how can I find which version of the ArcGIS Javascript API contains the Dojo v1.6.x version?
Thanks for any thoughts - Peter
RiyasDeen
Hi Peter,
  1. This link will provide version of dojo used  What's new in Version 2.8 | Guide | ArcGIS API for JavaScript (towards the end). Version 2.8 is the latest which uses dojo 1.6.1
  2. No API version is not dependent on ArcGIS Server version. However, for few functionality you'll need appropriate version of ArcGIS Server. E.g. print widget requires ArcGIS Server 10.1 because earlier version of ArcGIS din't have the required server component.
RiyasDeen
Hi Peter,
PeterLen
Riyas,
Excellent.  This is what I was looking for.  Thanks for your help.
- Peter
