Polygon in OSM layer
849
11-09-2010 04:13 AM
Hans-JürgenWeber
creating a graphics layer with a polygon works with esri streetmap layer (see attached example TestPolygonEsriStreetMap.html.txt), but it doesn't work with openstreetmap layer (see attached example TestPolygonOpenStreetMap.html.txt).
Any ideas what went wrong?
KellyHutchins
Esri Notable Contributor
It looks like the map's onLoad event wasn't firing. I moved the code that hooks up the onload event above the lines that add the openstreetmap layer and the polygon displays (see attached).
by Anonymous User
Not applicable
Original User: HJWeber
Thank you, that worked!
