Error trying to Register as Versioned (Merged threads)
7812
14
05-20-2014 10:46 AM
Lebowski
I am having troubling getting my database to register as 'Versioned." I added a feature class to the feature dataset but ended up having to delete it now I can not re-register the feature class as versioned, any thoughts?
Desktop Version 10.1, WIndows 7
VinceAngelo
Esri Esteemed Contributor
How did you drop the previous table?  With ArcGIS or from the database?
- V
by Anonymous User
Not applicable
Original User: zydeco42
- V
I deleted it from the database/feature dataset in ArcCatalog by right-clicking the feature class and selecting 'Delete.' Is that the correct way?
Lebowski
This is the message I receive in ArcMap when I try to start editing.
by Anonymous User
Not applicable
I deleted the feature class(es) from the database/feature dataset in ArcCatalog by right-clicking the feature class and selecting 'Delete.' Is that the correct way?
by Anonymous User
Not applicable
Original User: asrujit
Need some clarifications:
1. Was the Feature dataset already Versioned before you added the new FC(s)?
2. Did you Register as Versioned the dataset after adding the new FC(s)?
Sounds very basic, but close all the interfaces. reopen and then try the process...
AsrujitSengupta
This error usually points to a permission issue.
Try to add the entire Feature dataset in a new ArcMap session and try to start editing. let us know if you receive any errors in this process.
by Anonymous User
Not applicable
1. Yes the feature dataset was already versioned before adding the new feature class(es)
2. No I did not register as versioned prior to adding the new feature class(es), it was already versioned. I did however try to Version once I created the feature class(es). The problem occurred when I deleted the newly created feature class(es), I am now unable to preform any edits and cannot reconcile.
I have closed and open ArcMap & ArcCatalog several times, it did not solve the problem. The database lives on my supervisors machine and that has not been rebooted yet.
Lebowski
I just tried editing in a new ArcMap session still getting the same error
by Anonymous User
Not applicable
Original User: solxenos
Do you have a map service using the SDE database?
