How to Increment a String ID
828
05-20-2014 12:21 PM
MarkBasler
I'm using ArcMap 10.2 and I have an ID that is part Arcronym part part number.  I have created one script in the field calculator using Python to initially fill the field called FacilityID that I am populating as part of a Post Process.  What I need is a script for after the first run that will get the last three digits that are a number and use this to autopopulate Null FacilityID's.
Here is my original script.
    rec=0
    def autoIncrement():
     global rec
     pStart = 1
     pInterval = 1
     if (rec == 0):
      rec = pStart
     else:
      rec += pInterval
     return "water" + "11" + "-" +  format(rec, '04d')
Attribute Table :
[ATTACH=CONFIG]33941[/ATTACH]
