I have been trying to track down a "multipleDefine" error.In Chrome, I get this message:[ATTACH=CONFIG]33181[/ATTACH]in IE, I get this message:[ATTACH=CONFIG]33182[/ATTACH]So it would appear there is something to do with the BasemapGallery or something to do with the script I'm loading for esri. But who knows.The scripts I have loaded in my html are as follows (added at the end of the html):
</div> <!-- End Bottom Panel -->
</body>
</html>
<!-- JAVASCRIPTS ============================================================= -->
<script type="text/javascript" src="https://js.arcgis.com/3.8/"></script>
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.0/jquery.min.js"></script>
<script type="text/javascript" src="js/lib/modernizr.custom.js" defer></script>
<script type="text/javascript" src="js/lib/numeral.min.js" defer></script>
<script type="text/javascript" src="elements/search_wr.js"></script>
<script type="text/javascript" src="elements/search_latlong.js"></script>
<script type="text/javascript" src="elements/search_trsqq.js"></script>
<script type="text/javascript" src="elements/clear.js"></script>
<script type="text/javascript" src="elements/print.js"></script>
<script type="text/javascript" src="js/map_content.js"></script>
<script type="text/javascript" src="js/identify_by_json.js"></script>
<script type="text/javascript" src="js/identify_taxlot.js"></script>
<script type="text/javascript" src="js/search_wr_trs_ll.js"></script>
<script type="text/javascript" src="js/wr_time_slider_direct.js"></script>
<script type="text/javascript" src="js/wm_themeon.js"></script>
As you can see, this application has a lot going on and there are several .js files.But only one uses the basemapGallery.Other than the one place in the require statement, this is how the basemapGallery is called:
// Basemap Gallery
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
}, "basemapGallery");
basemapGallery.startup();
On top of this issue, I am having the issue of the basemap not always displaying. If I refresh my application several times in a row, about every 5th one will stop drawing the basemap - it'll just be white. But if I zoom a little, the basemap shows up. Maybe it's related, maybe not. Any ideas?Thank you.Dorothy
