Create Address Locator from shapefile crashes in ArcMap 10.2
3686
01-07-2014 12:37 PM
MarioSuau
I just installed ArcGIS 10.2 for Desktop. When I try to create an address locator in ArcMap or ArcCatalog from a shapefile, it crashes every time. I've done this before in version 9.3 and never had a problem.
Here are screen shots of my Create Address Locator screen with all of the settings that I'm choosing:
[ATTACH=CONFIG]30333[/ATTACH][ATTACH=CONFIG]30334[/ATTACH][ATTACH=CONFIG]30335[/ATTACH]
I've also attached a zip of the shape file I am trying to use.
Am I doing something wrong or is this a bug? Is there a workaround?
Mario Suau
Federal Signal - Alerting and Notification Systems
by Anonymous User
Not applicable
Original User: brad5993
Mario,
If you are seeing a crash you should contact customer support.  I was able to build a locator using the latest version of ArcGIS (10.2.1) with no issue.
Brad
MarioSuau
Thanks Brad,
I did contact support yesterday and they are looking into it. Out of curiosity, did you create the locator in 10.2.1 using my shapefile or another shapefile?
by Anonymous User
Not applicable
I created it with your shapefile.
Brad
