Workaround for tools "Select" and "Copy Features" in Model Builder
1330
12-02-2013 04:32 AM
by Anonymous User
Not applicable
Original User: jofuchs
Hi all,
I want to copy all features from feature class A, which have the identical attributes (only of one specific column) of another feature class B.
I thought about first selecting the features with the select tool and an sql query and than copying the selection with copy features.
My problem is the correct sql code block. I need something like:
"Select all features from FC A, where the attribute "ID" is the same like "ID" in FC B"
Can you help me with this problem?
Many thanks in advance! Im also glad, if there is another workaround to solve the problem. 🙂
DaleHoneycutt
You need to first establish a join between the two feature classes.
See About joining and relating tables.
In geoprocessing, you'd use the Add Join tool.  After selecting features with the same ID value, use Copy Features.
DaleHoneycutt
by Anonymous User
Not applicable
Thank you for your hints. That is another workaround which worked fine!
