Usage of iterator variables
1818
11-27-2013 05:45 AM
by Anonymous User
Not applicable
Original User: jofuchs
Hello everyone!
Normally I can use the model iterator variable (e.g. %Name%) in the final output filename so when the iteration is done the results are dynamically named. That is working so far in Model Builder. Now I try to name a new column of a feature class generated with "Add Field" with this iterator variable, but that does not work!
[ATTACH=CONFIG]29413[/ATTACH]
I just write down the Variable name in the "field name" like depicted in the Screenshot. I dont get any Error message. I only get the wrong column name "Name_IND_PC". The variable "works", because I am able to name the outputfile with it.
What am I doing wrong? Many thanks in advance for your help!
Jo
by Anonymous User
Not applicable
Original User: Hornbydd
What is the dataset you are creating the field in? If it is a shapefile then you can only have 10 characters, nor can you have unusual characters like /|\£$%^&*(.)
by Anonymous User
Not applicable
Thanks for your reply, it is an attribute-table of an point feature class. The length of the column name does not consist any forbidden characters nor is it too long (9 characters only).
by Anonymous User
Not applicable
Any other ideas, what can be the reason for failing the dynamic column naming?
Thank you!
Im also interested in other workarounds bringing me to the desired result!
