Problem with custom modules
2813
6
10-16-2013 07:37 AM
PeterMcBride
Hi All,
I am trying to practice accessing content from custom modules using the Home Button sample from the API tutorials. I have saved the HomeButton.js and the HTML page in the folder structure which is attached as images.
I have written the following HTML page to load the HomeButton but I get an "Object doesn't support this action" error when the page attempts to create a new HomeButton object.
I suspect that the issue is with the way I have entered the path to my custom module but I have tried loads of combinations and cant seem to find a solution.
The code is below and any help would be greatly appreciated!
Peter
<!DOCTYPE HTML>
<html lang="en">
<head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1">
    <title>Home Extent Button Dijit</title>
    <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
    <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="./ERMWidgets/css/HomeButton.css">
    <style type="text/css">
    body{
            margin:40px;
            padding:20px;
        .container{
            position:relative;
            padding: 10px;
            border: 1px solid #eee;
            -webkit-border-radius: 3px;
            border-radius: 3px;
        #map{
            width:100%;
            height: 500px;
            position: relative;
        #HomeButton{
            position: absolute;
            top:95px;
            left: 20px;
            z-index: 50;
    </style>
</head>
<body class="claro">
    <div class="container">
        <div id="map" class="map">
            <div id="HomeButton"></div>
        </div>
    </div>
    <h2>All Options</h2>
    <script src="http://js.arcgis.com/3.7/" type="text/javascript"></script>
    <script type="text/javascript">
       var dojoConfig = {
            async: true,
            parseOnLoad: true,
            isDebug: true,
            packages:[{
                "name": "ERMWidgets",
                "location": location.pathname.replace(/\/[^/]+$/, '') + "/ERMWidgets/"
        require(["esri/map", "ERMWidgets/HomeButton", "dojo/on"], function(Map, HomeButton, on){
            var myMap = new Map("map", {
                center: [-56.049, 38.485],
                zoom: 3,
                basemap: "streets"
            var myWidget = new HomeButton({
                map: myMap
            },"HomeButton");
            myWidget.on('home', function(obj){
                 console.log(obj);
            myWidget.startup();
    </script>
</body>
</html>
JeffPace
why are you saving out the hombutton.js instead of just calling it?
require(["esri/dijit/HomeButton", ... ], function(HomeButton, ... ){ ... });
by Anonymous User
Not applicable
Original User: peterm_erm
I am using the Home Button as a tester for defining custom modules. I know that it is now available as part of the latest API update but it is also the example used for defining custom modules in the API tutorials.
Peter
PeterMcBride
An update to this, I have done some more digging and using the developer tools in IE9 I can see that the requests are going to the right places so I am certain that my relative paths etc are working correctly. I have also updated the code to an example from the API samples so it now looks like this:
    <script>
          var package_path = window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/'));
          var dojoConfig = {
          packages: [{
          </script>
    <script type = text/javascript src="http://js.arcgis.com/3.7/"></script>
However I am still getting the 'Script445: Object doesn't support this action' error.
Any help would be gratefully recieved as I have been stuck on this for days!!
Peter
by Anonymous User
Not applicable
Original User: mattdriscoll
    <script>
          var dojoConfig = {
          packages: [{
          </script>
Peter
Seems like it's probably something in the module then. Is it returning a define function correctly?
PeterMcBride
Hi Matt,
I think the module is working correctly. I have modified it slightly from your GitHub version (mostly changing the definedClass and I removed the esri namespace section at the bottom as I didnt think I needed that?). I have included the code below, would you mind taking a quick look at it?
Thanks for your help.
Peter
define([
    "dijit/_WidgetBase",
    "dijit/_OnDijitClickMixin",
    "dijit/_TemplatedMixin",
    "dojo/Evented",
    "dojo/_base/declare",
    "dojo/_base/lang",
    "dojo/on",
    // load template
    "dojo/text!ERMWidgets/templates/HomeButton.html",
    "dojo/dom-class",
    "dojo/dom-style"
function (
    Evented, declare, lang,
    _WidgetBase, _OnDijitClickMixin, _TemplatedMixin,
    on,
    dijitTemplate,
    domClass, domStyle
    var Widget = declare([_WidgetBase, _OnDijitClickMixin, _TemplatedMixin, Evented], {
        declaredClass: "ERMWidgets.HomeButton",
        templateString: dijitTemplate,
        options: {
            theme: "HomeButton",
            map: null,
            extent: null,
            visible: true
        // lifecycle: 1
        constructor: function(options, srcRefNode) {
            // mix in settings and defaults
            declare.safeMixin(this.options, options);
            // widget node
            this.domNode = srcRefNode;
            this._i18n = i18n;
            // properties
            this.set("map", this.options.map);
            this.set("theme", this.options.theme);
            this.set("visible", this.options.visible);
            this.set("extent", this.options.extent);
            // listeners
            this.watch("theme", this._updateThemeWatch);
            this.watch("visible", this._visible);
            // classes
            this._css = {
                container: "homeContainer",
                home: "home",
                loading: "loading"
        // start widget. called by user
        startup: function() {
            // map not defined
            if (!this.map) {
                this.destroy();
                console.log('HomeButton::map required');
            // when map is loaded
            if (this.map.loaded) {
                this._init();
            } else {
                on(this.map, "load", lang.hitch(this, function() {
                    this._init();
        // connections/subscriptions will be cleaned up during the destroy() lifecycle phase
        destroy: function() {
            this.inherited(arguments);
        /* Public Events */
        // home
        // load
        /* Public Functions */
        home: function() {
            var defaultExtent = this.get("extent");
            this._showLoading();
            if(defaultExtent){
                return this.map.setExtent(defaultExtent).then(lang.hitch(this, function(){
                    this._hideLoading();
                    this.emit("home", {extent: defaultExtent});
            else{
                console.log('HomeButton::no home extent');
        show: function(){
            this.set("visible", true);
        hide: function(){
            this.set("visible", false);
        /* Private Functions */
        _init: function() {
            this._visible();
            if(!this.get("extent")){
                this.set("extent", this.map.extent);
            this.set("loaded", true);
            this.emit("load", {});
        _showLoading: function(){
            domClass.add(this._homeNode, this._css.loading);
        _hideLoading: function(){
            domClass.remove(this._homeNode, this._css.loading);
        _updateThemeWatch: function(attr, oldVal, newVal) {
            domClass.remove(this.domNode, oldVal);
            domClass.add(this.domNode, newVal);
        _visible: function(){
            if(this.get("visible")){
                domStyle.set(this.domNode, 'display', 'block');
            else{
                domStyle.set(this.domNode, 'display', 'none');
    return Widget;
by Anonymous User
Not applicable
Hi Matt,
Peter
define([
    "dojo/Evented",
    "dojo/_base/lang",
    "dojo/on",
    // load template
    "dojo/dom-class",
    "dojo/dom-style"
function (
    on,
    dijitTemplate,
    domClass, domStyle
        options: {
            map: null,
            extent: null,
            visible: true
        // lifecycle: 1
            // widget node
            this._i18n = i18n;
            // properties
            // listeners
            // classes
            this._css = {
                home: "home",
                loading: "loading"
            // map not defined
            if (!this.map) {
                this.destroy();
                this._init();
            } else {
                    this._init();
        /* Public Events */
        // home
        // load
        home: function() {
            if(defaultExtent){
            else{
        show: function(){
        hide: function(){
        _init: function() {
            this._visible();
            else{
    return Widget;
Ah, it looks like the define arguments are out of order.
They should be like this:
