Is there a way to combine fields when using the Union tool?
2451
08-30-2013 06:45 AM
ReneeCammarere
I have two feature classes, treesa_clip and orchard_clip.  The fields for the first one looks like this . . .
[ATTACH=CONFIG]27113[/ATTACH] and the fields for the second one looks like this . . .
[ATTACH=CONFIG]27114[/ATTACH]
When I use the Union tool to combine the two into one feature class, I end up with 28 fields, in other words, even though there are fields in common (with common names), it creates two separate fields for those (such as f_code and tile_id).  Is there a way that I could get the Union tool, or some other tool, to create an output feature class that also combines fields with names in common?
Thanks!
by Anonymous User
Not applicable
Original User: timw1984
You have all the attribute fields in your output because when the 2 features overlap there would be 2 different values in for example your f_code field. Union creates a separate feature for every time your 2 input features overlap.
You could use the merge tool if they don't overlap http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000055000000
by Anonymous User
Not applicable
