FeatureLayer Legend widget issue
1407
08-15-2013 03:04 PM
TerryGiles
I have a featurelayer in my map which contains polygons with an outline but no fill.  It displays in the map correctly, but in the legend widget, it shows up with a black fill (under 'UpperColorado' in the 1st image below).  If I look at the legend for the map service's REST endpoint, the symbol looks correct (2nd image).
Any idea how to fix this?
Thanks, TG
[ATTACH=CONFIG]26734[/ATTACH]
[ATTACH=CONFIG]26735[/ATTACH]
by Anonymous User
Not applicable
Original User: uppudada
var layer = new esri.layers.FeatureLayer("http://servername:6080/arcgis/rest/services/test/test_Dis/MapServer/1", {
mode : esri.layers.FeatureLayer.MODE_SNAPSHOT,
opacity: 1.0,
outFields : ["*"]
You can use opacity: 1.0 for not displaying fill color in legend....
Upendra
JasonZou
Interesting result. Unfortunately, I don't think there is something you can do with the legend dijit result. I would try two alternatives:
1. Use agsjs.dijit.TOC developed by nliu. (http://www.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109)
2. It's not too hard to develop a custom one using REST API, especially if you only want to display the legend, not to have it also works as Table of Content.
by Anonymous User
Not applicable
opacity: 1.0,
outFields : ["*"]
Upendra
TerryGiles
Thank you Upendra, explicitly setting the opacity as 1.0 solves the problem.
Terry
