Geocoder returns matching address for 0-0 range
1888
06-24-2013 09:15 AM
by Anonymous User
Not applicable
Original User: shaunrconway
Hello Everyone,
ArcGIS 10 SP5 - SQL Server 2008
We have an address locator built off of our street centerline feature class. Some of our street segments will have an address range on one side of 0-0. This occurs along our divided highways / streets. Our problem is that any address along the entirety of the street (any segment) will be geocoded against the segment that has a range of 0-0.
For example, we search for 902 Church St. The geocoder first two results are for the divided section of road, block 1400 Church St.
Hard to explain so I attached two images. One details the error and the other displays the settings for our address locator.
Shaun
[ATTACH=CONFIG]25445[/ATTACH]
[ATTACH=CONFIG]25446[/ATTACH]
JoeBorgione
Hello Everyone,
Shaun
And even harder to understand;  To me your illustration shows two segements; one has a range of 0-1414 and the other 0-1411.  902 falls well within that range.
Check your street data, and be sure your 0 - 0 ranges are on one side or the other.
by Anonymous User
Not applicable
Thanks for such a quick response.
The address ranges are as follows in our feature attribution:
(For single/non-divided segment of Church St)
Address Left To: 1400
Address Right To: 1412
Address Right From: 1401
Address Right To: 1409
(For western segment of Church St)
Address Left To: 0
Address Right To: 0
Address Right From: 1411
Address Right To: 1499
(For eastern segment of Church St)
Address Left To: 1414
Address Right To: 1498
Address Right From: 0
Address Right To: 0
ShaunConway
Figured it out ............ and its embarrassing :rolleyes:
The "From Right" parameter in our address locator is set to Addr_LTo instead of Addr_RFrom.
So this would cause the range to be 0 - 1499 as you pointed out.
Thanks!
by Anonymous User
Not applicable
Original User: jborgion
oops....   :rolleyes:
