Create a line from a single point
4418
06-11-2013 10:37 AM
by Anonymous User
Not applicable
Original User: Astronomic
I have a table with several points and each point are associated with a length and angle.
I need to create a line or segment from a single point from the length and angle. The coordinates of the point (X, Y) mark the center of the line.
Someone knows some tool or script to create this.
Thanks in advance
[ATTACH=CONFIG]25201[/ATTACH]
markdenil
Bearing Distance To Line (Data Management)
by Anonymous User
Not applicable
Thank you mdnil,
Did not know this tool, greats!.  But de problem is that the point is not in the center of the line.
Any solution for this?
markdenil
Run the tool twice,
once with the angle you have recorded
and again with the reciprocal angle (180° different).
Merge the feature classes and dissolve the line features using
the UNSPLIT_LINES setting.
JoseSolanako
Good idea!
But with half the length each time.
Many thanks!
All the best!
