Model Builder Not Completely Honoring Layer File
1205
04-22-2013 06:53 AM
CraigMcDade
I have created a series of map templates for one of our departments that each have an associated model.
As part of the model I also created a lyr file for symbology and labeling (the subject parcel layer portion).
[ATTACH=CONFIG]23705[/ATTACH]
This is referenced in the output feature properties of my model.
[ATTACH=CONFIG]23706[/ATTACH]
The tool runs correctly and the Subject Parcel_layer gets added to the map template. The overall symbology from the layer file is correct, however, the labeling preferences I've set up are not (font size, type, etc.).
As a side note, the Subject Parcel Layer does not exist in the template, it gets added through the model.
Any ideas on why the labeling portion is not being honored?
by Anonymous User
Not applicable
Original User: j_orellana
I believe Layer files do not store Labelling properties. If you wish to apply the same labelling scheme to a new dataset, I suggest changing the source file of the existing data set that is labelled properly and point to your new dataset.
Hope that helps
