Feature appearance different in data and layout view
2109
01-22-2013 02:13 PM
WadeCampbell
I'm trying to output a map and have run into a strange issue I've never encountered before. In the data view, I've increased the thickness of a few polyline and polygon-boundary lines to emphasize them better. However, when entering layout view, all of the lines/boundaries in the extent are uniformly non-thick (i.e. default .4 thickness). I switch back to data, thicker; layout, skinny.
Because I received these shapefiles from another colleague, I've poked around and looked to see if there were any scale ranges that had been set or the like. Answer - no.
I apologize for being less precise than some might hope, and to that end I've included a couple screenshots of the data and layout views.
If anyone has any experience with dealing with something like this, I'd appreciate the help.
WadeLobb
Long shot but do you have a Reference Scale set? Try right click on data frame (in Table of contents) go to Reference Scale and Clear reference scale.
