Hi all,
I have a very fine square grid in a raster format that I am having problems with. It was originally a polyline feature class but I did not like the fact that it had over 1000 seperate lines in the attribute table so I made it a raster so it is just one (so when it is published it is easier to query).
However, when I view the raster at full extent Arc 10 decides to draw random lines (first image) instead of just a block of colour like the polyline one did (second image) which is what I want it to look like as the random lines look messy.
[ATTACH=CONFIG]19520[/ATTACH] [ATTACH=CONFIG]19519[/ATTACH]
When the raster is zoomed in the random lines showing change until zoomed in to a certain level and the correct grid shows. I have messed around with the pyramids on the raster to see if that does anything but I don't really know what I'm doing there.
I don't even know if it is possible to show the full grid at full extent with a raster as Arc is trying to draw it dynamically and I don't want that, is there a way to turn that off?!
Thanks, any advice will be appreciated, even if it is to tell me its not possible!
Holly
