Field Calculator - Python - using 3 fields for parameters get syntax error
2061
11-21-2012 07:43 AM
by Anonymous User
Not applicable
Original User: lbowman
I'm trying to create a model to do field calculations using 3 fields for parameters. I get the attached syntax error when I do. I'm successful in using 2 fields as parameters but when I add the 3rd, I get the error. Is there a limit or am I doing something else wrong?
Other suggestions for doing field calculations which could be easily modified by another.
Attached is the field calculator w/ code and error.
Any help would be very much appreciated. Thank you!
MathewCoyle
Honored Contributor
Can you copy and paste your code instead of using a screen shot? It is a little difficult to make out.
What are the data types of your three fields? Which field and code did you add that introduced the problem?
by Anonymous User
Not applicable
Thanks for the quick reply. I thought it was adding the 3rd field but it seems that it is the 3rd field that I've added that's the problem. If I only add this one field which is a text field with coded-value domain, it fails.
Expression:
calcCompliance(!rail_alignment!)
Code Block:
def calcCompliance(align):
      return None
Error:
Executing (Calculate Field): CalculateField "Existing Guide Rails" compliance calcCompliance(!rail_alignment!) PYTHON_9.3 "def calcCompliance(align):\n      return None\n"
Start Time: Wed Nov 21 13:20:35 2012
ERROR 000539: <type 'exceptions.SyntaxError'>: invalid syntax (<expression>, line 1)
Failed to execute (Calculate Field).
Failed at Wed Nov 21 13:20:35 2012 (Elapsed Time: 0.00 seconds)
If I change the field used in the expression it works just fine. The field is a text field, length 25, and does contain double quotes. But one other field I tried has double quotes (but only 1 per record, the field that it fails on has some records with 2 double quotes as such:
6" - 12" Out of Alignment. Would it be failing because of that?
Let me know if you have any suggestions. Thanks!
LaureBowman
The problem was a field where records had 2 double quotes. Using the following for the Expression:
calcCompliance(!rail_elem_cond!, !rail_ht!, '!rail_alignment!'.replace("\"",""))
solved the problem. I got this from a post on Stack Exchange.
Thanks for trying to help!
