testing for raster
1842
10-29-2012 06:13 PM
by Anonymous User
Not applicable
Original User: dhealey
In 10.1, I'm using  FC_List = arcpy.ListFeatureClasses() to capture a list of fc's names,
    but some of those are also raster.
Now, I'm not seeing that in the doc http://resources.arcgis.com/en/help/main/10.1/index.html#//018v00000018000000.
    However, to humor me.
Using Arcpy, what test can I use to distinguish fc from raster?
As in perhaps...
for name in FC_List:
   if name.ObjectType_for_example == "raster":
      process_raster(name)
   else:
      process_fc(name)
by Anonymous User
Not applicable
Original User: Caleb1987
You can use the list rasters function:
rasterList = arcpy.ListRasters()
for raster in rasterList:
    print raster
by Anonymous User
Not applicable
You can try something like this:
arcpy.env.workspace = r'C:\temp'
    print raster
    # do something with these
fc_list = arcpy.ListFeatureClasses()
for fc in fc_list:
    print fc
by Anonymous User
Not applicable
Original User: curtvprice
That list function should be only return feature classes. ListDatasets gives you both flavors. But to answer your question, the properties of an object are determined using the Describe function. You're looking for the "datasetType" property:
Dataset properties
arcpy.Describe(dataset).datasetType in ["RasterDataset","RasterBand"]
by Anonymous User
Not applicable
<<That list function should be only return feature classes.>>
Yes, that is what the docs say, but I do not have time to wrestle with tech support.
I saw the <<arcpy.ListRasters>> already and would have used it if needed, thx.
<<arcpy.Describe(fc).datasetType>> works great and will probably use is more often.
Thank you both of you.
