Issue Importing XML Schema in ModelBuilder
2371
10-16-2012 09:14 AM
EricBay
I'm running ArcDesktop 10 with an ArcInfo License.
I am trying to automate several processes that I do on a nightly basis. One of which being the creation of a geodatabase from XML data exports. I can create them without issue using ArcCatalog, but when I try to do the same thing in ModelBuilder the 'Import Schema and symbology from:' is greyed out. I am probably missing a step in here somewhere.
Creating Via ArcCatalog:[ATTACH=CONFIG]18458[/ATTACH]
Creating Via ModelBuilder: [ATTACH=CONFIG]18459[/ATTACH]
Any help would be greatly appreciated!
Eric
by Anonymous User
Not applicable
Original User: JB4Pres
Could this be because I do not have the Data Interoperability Extension? Seems like if I can complete this process manually in ArcCatalog I should be able to do it in ModelBuilder.
JoeBryant1
I'm guessing this is because you need to add a step in ModelBuilder to connect to the geodatabase first before you will able to export the XML.
As indicated here: https://community.esri.com/t5/data-management-questions/import-export-xml-workspace-document-disable...
