Solved! Go to Solution.
I have a map I have been working on (view-able at http://www.arcgis.com/home/item.html?id=c0bcad5921d54e6ab5f2d212fc42dd7e). I have a layer of streets that will not display correctly. I have the visibility range set so that it is only visible when in closer than 1:80,000; however, when the zoom range is close to but less than 80,000 the map only displays a portion of the streets. The closer you zoom in, the more streets become displayed.
Does anyone know what the problem is and how I might can fix it?
I appreciate any info!
What Internet browser are you using?
