Direction Connection to ArcSDE Problems
3106
04-30-2012 11:02 AM
Jay_Gregory
I've inherited a SQL & ArcSDE / ArcGIS Server stack (SQL & ArcSDE on one machine, ArcGIS Server on a second).
I'm using the instructions here: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Geodatabase_connections_in_ArcGIS_Desk...
I can successfully create a connection is I DON'T use the direct connection syntax, and instead use just the port number (5151).  Please see the two images below.
When I change the service field to use a direct connection string, all the sudden I get a bad login user error, even though I did not change the account credentials.  Any assistance would be appreciated.
This connection doesn't work... (failed to connect to the specified server. Bad login user).
[ATTACH=CONFIG]13954[/ATTACH]
This connection does work.
[ATTACH=CONFIG]13955[/ATTACH]
by Anonymous User
Not applicable
Original User: kpeter
Is the SQL Server Browser service running for the SQL Server instance?  By default, named instances of SQL Server don't use a specific port, and you need the SQL Server Browser to identify the port number.  If the SQL Server Browser is not running, was the instance explicitly set to use a specific port number?  If so, then you should specify that port number after the instance name in the service connection string:
sde:sqlserver:myservername\mssqlserver,<port#>
by Anonymous User
Not applicable
Unless your SQL Server instance name includes ":5151", take that out of the direct connection syntax.  It should be
assuming that your SQL Server instance name is myservername\mssqlserver.
Jay_Gregory
If I take out the :5151, I get a completely different error
Failed to connect to the specified server. Failure to access the DMBS server
I assumed that the bad user login error was better because at least it got to the authentication stage (and failed).  This error seems a little trickier to troubleshoot, particularly I was able to access the database using just the port in the "service" field.  Any idea on how I could troubleshoot this error?
I'm running SQL Server 2005 on my SDE machine, and have the 2008 native client on my ArcGIS machine...
Thanks, Jay
by Anonymous User
Not applicable
Jay_Gregory
Thanks - I took a look around the configuration manager on SQL, and saw that the TCP/IP protocol was using a different port (not 5151).  The browser service was running, so I replaced my connection string with yours, sde:sqlserver:myservername\mssqlserver,<port#>, specifying the correct port number, and the connection worked!
Thanks again for your help.
Jay
