Shapefile objects not resizing when zooming
4414
02-27-2012 12:39 PM
NeilUnderhill
When I zoom on one of my maps the symbols and text for particular shapefile objects do not resize (no-resize.jpg).  On other maps the text and symbols are constant size regardless of the map scale (resize.jpg).
The only special thing about the problem map is that I have defined the projection myself (the problem happens with all shapefiles in the map). Can this cause an issue?
Or is there a setting somewhere to keep text / symbol size constant regardless of map scale?
Neil
by Anonymous User
Not applicable
Original User: tereshenkov
Do you have reference scale enabled for your data frame?
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00660000043v000000.htm
NourSalamJMT
This was so helpful.
NeilUnderhill
Thanks Alexey, I had a fixed reference scale.  Changing it to <None> fixed it.
Neil
by Anonymous User
Not applicable
Awesome. 🙂 Don't forget to mark the post as answered.
